SecurityTrackWorld ...
[Closed] SecurityTrackWorld - lock removal
So after successfully swapping the front door lock to an Avocet ABS I want to swap the back doors to matched locks.
It's a set of double doors - I can get one lock out no problems, but the other side is leaving me scratching my head abit.
This door locks top & bottom:
Have had the handle off but there is still something holding it.
Nothing obvious through the frame for a retaining screw.
Do I need to take the strike plate off the door and see if it's under there?
Or am I missing something obvious?
Thanks
Posted : 04/04/2020 2:54 pm
I'd take that metal plate off. Euro cylinders are held in place with a screw that would normally be somewhere around that plate.
Posted : 04/04/2020 3:00 pm
You might need to call a locksmith.
Don't worry about trying to get one during the Corona crisis, I hear they are key workers.
Posted : 04/04/2020 3:03 pm
Don’t worry about trying to get one during the Corona crisis, I hear they are key workers.
Just how long have you waited for this thread to come along?
Posted : 04/04/2020 3:15 pm
It'll be the same as the one you've done, to the best of my knowledge it's a standard, there's no other way of securing them. Presumably the screw is under that plate.
Posted : 04/04/2020 3:19 pm
Thanks all.
Sussed it out now.
Took the plate off and the retaining screw is about 30mm further down - can just see it through the hole.
Need to take the extension piece of the side of the door - held on with 100mm tech screws - to get to it.
New locks now ordered to match the front door.
Posted : 04/04/2020 5:09 pm
