Running gillet
[Closed] Running gillet
9 Users
I want something to wear over my Craft Extreme windstopper base layer. Something to keep the chill off, but not too warm.
Any recommendations?
Posted : 27/11/2012 10:53 am
Saucony Epic Gilet, tis what I use.
So far has proven to be a very good buy. The reflective strips are quite good.
Posted : 27/11/2012 10:59 am
How's the running been going anyway?
Posted : 27/11/2012 11:07 am
Good thanks, enjoying it. I'm gradually building up the distances and doing around 6.5km at the moment; all off road and with some fairly steep hills included. I'm supplementing it with some treadmill work in the gym, just to get the muscles and tendons working.
Unfortunately my leg injury has come back (nothing to do with the running) so may not be able to do much for a bit.
I can recommend the Asics Gel Fuji Trainers I bought.
Posted : 27/11/2012 11:30 am
I'm using an Altura Night Vision Gillet at the moment, not at thin and light as some, but very visible.
Posted : 27/11/2012 11:38 am
I'm not bothered about visibility as I am running off-road.
Posted : 27/11/2012 11:40 am
The Gore one I got this year is good but a little shapeless (you'd need a big belly to fill it). The Concurve one I had previously was much more snug.
Posted : 27/11/2012 11:43 am
Bump!!! 8)
Posted : 27/11/2012 8:28 pm
Could someone explain how a running gilet would differ from a cycling gilet? For what it's worth, I'm using the Endura Equipe gilet for both. Thin and wind proof.
Posted : 27/11/2012 8:31 pm
The Gore one I got this year is good but a little shapeless[b] (you'd need a big belly to fill it)[/b]
Cool, sounds perfect 🙂
Posted : 27/11/2012 8:34 pm
That is a good question, as I am also considering using my Gore Phantom 2, with the arms taken off.
I guess the main difference is the cut. I would also guess that they don't need to be as warm as you don't have the same level of wind (due to the lower speeds) and the upper body moves more when running.
Posted : 27/11/2012 8:35 pm
I would have thought that would be too hot, as it's quite thick.
Something like this, maybe?
http://www.chainreactioncycles.com/Models.aspx?ModelID=82471
...personally, if it's cold but not wet, I just put a running vest under my Gore windproof base layer for a bit of added warmth.
Posted : 27/11/2012 8:36 pm
That is my thinking too.
I may try a few of my existing items of technical clothing before I take the plunge, but it doesn't hurt to look.
Posted : 27/11/2012 9:49 pm
Is there a running equivalent to the likes of dhb? Cheap, but reasonable quality and functionality.
Posted : 28/11/2012 9:36 am
convert, which is the belly one? sounds great for what i need.
Posted : 28/11/2012 9:53 am
 r0bh
Montane Slipstream Gilet
http://www.montane.co.uk/products/men/windproof/slipstream-gilet/245
Posted : 28/11/2012 9:57 am
If you can fit a small or a medium:
http://www.tgstore.eu/running-vest-p-3364.html
Free delivery and 15% off with code: TGGIFTPACK
Posted : 28/11/2012 6:18 pm
