Running a campervan...
[Closed] Running a campervan fridge while charging
 ed34
I don't have a 240v adaptor for my domestic campervan fridge, I could buy one but the 240v/12v dual power relay thing is about 90 quid
Fridge power is about 5a 40w according to specs.
So if I have say a 10A smartcharger and leave that connected to the battery and mains hook up, it should keep battery charged while fridge is running?
Thanks
Posted : 02/02/2022 4:29 pm
Yeah, it'll be fine. The way our hookup works for any 12v stuff, including the fridge, is that all that stuff runs from the leisure battery, and the hookup is attached (via a little consumer unit) to a 240v charger that charges the battery. You're essentially doing the same thing.
Posted : 02/02/2022 4:34 pm
Sounds fine. My smart charger has a power supply mode where it will limit the voltage to 13.5V so you don't leave the battery at too high a voltage for too long. But for a few hours/days it should be fine, and the fridge isn't on continuously anyway so when the fridge compressor stops the charger should see the full battery and stop too.
Posted : 02/02/2022 4:45 pm
Yep. As IHN says.
Posted : 03/02/2022 9:04 am
