anyone got a good ideas/recomendations for non slip flooring for a vauxhall combo van, the dogs getting a bit tired of sliding around
Better to put a cheap bit of carpet in there Pouch will like it a lot better
http://www.quattro.org.uk/equine/
I have just done my Vito Van out with some of this,Some of this gear is a bit heavy though,and you dont need rubber, 5mm foam is light and works best and can be cut easily and wiped clean if needed,they do mail order too.
I used a rubber granule mixed with resin compound its what they use on horsebox floors and its water proof you mix it together and lay it with a trowel.I have had it in my works van for 6 years cost about 150 quid to do a lwb Renault master
I got some rubber sheeting ~10mm thick from B&Q which i use to line my berlingo - though just the back half so I can get the seats in ok. Was about £15 and sold as "rubber runner"
