Roofbars/Bike Racks...
[Closed] Roofbars/Bike Racks/Load Stops with T-Tracks compatible with Thule.
8 Users
Apparently there are firms apart from Thule who make Roofbars/Bike Racks/Load Stops that are compatible with Thule T-Tracks. (20mm IIRC.)
Is that correct?
Which manufacturers?
TIA.
Posted : 05/06/2018 8:46 am
I'm sure it must be a pretty standard fitting. I have Alfa branded bars on my car and the Thule bike carriers fit on perfectly with the t-tracks.
Posted : 05/06/2018 9:16 am
I got some G3 CLOP Steel roof bars from www.micksgarage.com which were compatible with the t-track fittings on my Atera Giro bike rack. Atera is another brand which would be compatible.
Posted : 05/06/2018 10:34 am
Any t-track style bar should work with 20mm x 20mm t-tracks.
Cruz
Rhino
The recent Aldi ones (?)
Posted : 05/06/2018 9:32 pm
To add to the above, my Exodus roof box with Exodus branded T track adapters fit perfectly on my Thule roof bars, so seems to be a pretty standard fitting.
Posted : 05/06/2018 9:54 pm
think there's only two sizes 20 (most) & 24mm (kamei?). Roofbox sell t-track bolts that are 20x24mm so you can use in either.
Posted : 05/06/2018 11:13 pm
The only one I’ve ever seen mentioned as different (after doing lots of research on various sites) is the BMW own brand rails which seem to take a different T track shape but you can buy new bolts for bike holders so you can mix and match if you have BMW rails.
Posted : 06/06/2018 12:44 am
The Aldi/Lidl ones I have (made by an Italian company who's name escapes me) have a smaller T-Track size. (15mm IIRC.)
Exodus is useful - thanks.
Posted : 06/06/2018 9:15 am
I had some M-Way brand on an Astra estate that I used the t-track kit on.... came from roofbox.co.uk IIRC.
Posted : 06/06/2018 1:50 pm
