Right Angled Sofas
[Closed] Right Angled Sofas
You know them sofas that do a right angle?
Are they all bolted together so the right angle is fixed or can you make them like, 120 degrees or something? I only ever see them advertised in a right angle configuration but our living room is a funny shape with quite a big bay so we want it to extend into that rather than turning at 90 degrees.
Posted : 26/01/2014 10:27 pm
But then you would have a gap.
They are normally fixed somehow hut I am sure you could put some kind of spacer block in to open it out.
Posted : 26/01/2014 10:29 pm
Had one once, wasn't fixed at all, like two sofas just pushed together.
Think it was an cheap sweedish one I saw fixed. Maybe it was because the legs on one side acted as legs for the other to save materials or probably just needed to stiffen it up. Never found one of their sofas I thought was comfy. More heavy duty makes might be better.
Posted : 26/01/2014 10:34 pm
You can get ones which are curved - with segments on the bend. Miss out a segment, and hey presto! etc
Posted : 26/01/2014 10:40 pm
You know. There are shops. They sell this shit. Go take a look.
#justanidea
yeah, I like asking people who have had experiences before I go and visit shops, ta.
Posted : 26/01/2014 10:46 pm
No idea on the angle thing but where do you find that sofa in the picture it looks rather nice.
Posted : 26/01/2014 10:49 pm
Yes and No! I think it all depends on design and where you get it from!
Posted : 26/01/2014 10:52 pm
Experienced at buying sofas at specific angles?
Posted : 26/01/2014 11:03 pm
Someone who has experienced these things before, yes.
There will be lots of people here who own a right angled sofa so they'll be able to tell me if they are fixed, are just some sofas pushed together or can be changed in angle.
Matt, it was from this website. Looks terribly expensive.
[url] http://www.bebitalia.com/ [/url]
Posted : 26/01/2014 11:06 pm
Good luck in your endeavours. I'm off to bed.
Posted : 26/01/2014 11:13 pm
thinking about it again it may have been because it was a display model to stop the parts separating on the shop floor and causing someone to have an accident. I remember as it was in the bargain bin and the people buying it had a lot of trouble getting it apart.
The only ones we've had, have had locking pins that hold the two pieces together.
Posted : 26/01/2014 11:17 pm
They're often fixed together, depends on how heavy they are - a bigger heavier one isn't going to wander about. Even if they are ones that fix together they'll still be delivered in sections (otherwise they'd never get through the door) so you can still unfix them if you want.
Sometimes they're in two parts, sometimes in three, with the 90 deg corner being its own small unit and two straights either side. In that latter instance you would maybe able to find the corner bit in varying angles, but probably as a custom option rather than off the peg, but if not, and you wanted to open up the angle a bit then one in 3 segments means you'll at least have two smaller gaps rather than one big one
Posted : 26/01/2014 11:18 pm
I reckon the corner part that creates the angle can be made in different models but they only show 90 degree ones. We'll be going down the shops as John very helpfully suggested but obviously if anyone can confirm they have one in a different arrangement that wold be appreciated.
Posted : 26/01/2014 11:20 pm
 JoeG
Will any of these work?
[img] %3Fw%3D560[/img]
Posted : 27/01/2014 1:14 am
awesome. I love the green snake one.
Posted : 27/01/2014 3:49 pm
