Reversing Bulb Repl...
[Closed] Reversing Bulb Replacement
5 Users
The reversing lights on the PinkMobile are, to be frank, absolutely abysmal, can hardly see a thing behind me when I'm reversing onto my drive, so I've decided to try & replace them.
Problem is I can't find find anything brighter than a P21W that will do the job.
does anyone out there have any suggestions on what I can replace the current P21W's with?
Cheers.
Posted : 16/01/2015 10:49 am
Just reversing onto your drive? Wouldn't it be easier to provide lighting from something other than your car?
Posted : 16/01/2015 10:53 am
turn on your foglight is how i cope when reversing into dark driveways.... but as above - i just fitted lighting on my drive so it was not a dark drive.
Posted : 16/01/2015 11:01 am
Well it's reversing a lot of places TBH. And replacing with brighter bulbs would be a lot cheaper than installing lighting to the end of the drive.
Posted : 16/01/2015 11:02 am
just fit a foglight bulb.
they tend to be brighter - and usually its the lense in most cases that makes it red.
on my cars - one side is the foglight and the identical light/fitting on the otherside is the reversing light.
but as i said my reversing light is pish so i just turn on the fog light when i need the extra light.
Posted : 16/01/2015 3:46 pm
I checked my bulbs, and as I thought both the fog and reversing are 21W, which I thought was the highest rating for a standard (non headlight) bulb. Though they're not interchangeable anyway as the fog is a dual filament with the tail light.
The reason for recommending something other than upgrading the bulbs is that you're unlikely to be do that easily.
Posted : 16/01/2015 4:17 pm
Replace the P21W with an LED - you'll get substantially more light out of an LED.
Posted : 16/01/2015 5:01 pm
Fit extra lights or brighter led bulbs
Read through this thread here
http://www.disco3.co.uk/forum/topic102957.html
When I had the landrover I discovered that there was wiring on both sides for a reverse lamp but only a lamp on one side, possibly for left hand drive markets. I bought another lamp and wired it in hence the extra light below the foglight. I also fitted the rear work lamp with a 100watt bulb and a switch on the dash to turn it on when reversing. Also useful for tail gaters or those who didn't dip when behind......
http://www.macmillan4x4.co.uk/Photos/landy12.html
Posted : 16/01/2015 5:27 pm
