Replacement window ...
[Closed] Replacement window question .
7 Users
Just found out today lounge bay windows deaded !! How do i get a quote without enduring the usual smarmy over aftershaved slime balls who won't take NO for an answer? Tried on line quotes no dice want my details so Mr Sleaze bag can call round.
Posted : 19/04/2009 7:28 pm
Just give a local glazier a bell. Ive just had a new plastic one 1800 X 1200 with toughened glass for £210 (not a bay tho)
Posted : 19/04/2009 7:37 pm
Go local not national.. avoid Everest.. Anglican et al. See your local word of mouth referenced chippy.
Posted : 19/04/2009 7:41 pm
Agreed - local carpenter and get decent wood ones.
Posted : 19/04/2009 7:43 pm
Where are you?
Why avoid Everest Anglian etc HUGELY overpriced ?
Posted : 19/04/2009 7:44 pm
bear uk Somerset.
T.J Going PVCU to match rest plus had enough of wood thanks.
Posted : 19/04/2009 7:47 pm
To far for me to travel.
Just go for a couple of local firms, or if there are any window trade places around your area.
Posted : 19/04/2009 7:50 pm
I had some good work done by notaro from bridgewater.
Posted : 19/04/2009 7:53 pm
Sorry to bear bad news but replacing a bay is the most expensive/hardest window to replace.
They have to be measured accurately as no 2 bays are the same.I.e the angles are different/each side could be different lengths.
The removal and fitting isnt straight forward either as whilst removing, the bay has to be supported(usually by acros) so as not to collapse.
It also depends on how high the start of the glass is from the floor as to whether you will need toughened glass(under 800mm = more expense)
Been out of the game for a few years but I personally hated doing bays.
I would also use a decent local chippy as they usually take more pride in their work(not thrashing around and leaving untold amount of mess everywhere and taking shortcuts because they are paid by the day...not for a good job done
hope this helps a little
Posted : 19/04/2009 7:56 pm
jambo and trans 13 thanks for info .
Posted : 19/04/2009 8:02 pm
