Just removed a paper border from our girls room prior to repainting and in three places the skim coat has 'blown' away from the base coat. The holes are a maximum of 12" diameter and the skim is about 3mm deep at a guess.
Can I use a normal filler to repair these or is there something that will be easier/better?
yes, normal filler, applied with a 10" taping knife. 2 coats then sand.
Great.... what's a taping knife? Just measured again and the diameters are 10-12", still the same solution?
result.... looked in the shed and found an unopened box of plaster repair filler.
First coat on - cheers LB
once the first fill is dry, sand it down and refill, once that is dry fill again etc etc etc
Its all in the preparation to get a good finish.
