I've a recently fitted aluminium front door that has a thin plastic film on and is proving to be a bit difficult to remove.
It's coming off in 5p sized bits at best.
Any tips?
Posted : 10/10/2016 8:37 am
Hair dryer to soften up and should just peel off.
Posted : 10/10/2016 8:38 am
Tried that but still won't shift?
Posted : 10/10/2016 8:41 am
Heat it up until you can lift a corner then put the air direction under the bit you've lifted and gently pull.
Posted : 10/10/2016 8:55 am
