What is the best product / method for removing graffiti off an old stone building?
No advice to give but I assume you are planning to remove the graffiti from Ryvoan- Well done you! what kind of dick does that anyway?
If you weren't planning that but find something that works, let me know what it is 🙂
Ha. You guessed! I avoided sharing a photo of it as dicks like that don't need the publicity.
I used nail varnish remover on my wife's car. Brought the graffiti off ok.
Can't advise on product/method but you could contact local council for suggestions as it's something they (probably) deal with regularly.
Our local council use a jet wash with glass pellets in it. Gets the graffiti off but leaves a huge pile of waste abrasive behind.
Pressure washer should get it off just be careful you don't damage the wall with the water's pressure, other than that paint stripper will work, just leave for an hour or two then wash off
You're going to need a hell of an extension lead
You’re going to need a hell of an extension lead
Our eatates department use a pressure washer with a dirtblaster nozzle to remove graffiti from brickwork.
Not much use somewhere without power or water though.
Aye. Nae power nearby. Jet wash etc isn't an option so looking like some kind of paint stripper and a fee trips back and forth for water.
I've used DOT4 brake fluid to clean off spray paint. Depending who you believe, it's low toxicity and water soluble or poisonous to everything - it might depend on what additives are in it.
I reckon for rough stone, away from power and water, then a wire brush and elbow grease is your only option.
Brake cleaner, cellulose thinners, white spirit or chlorinated rubber thinners, combined with a stiff brush and elbow grease should all do the trick I imagine...
As you can’t spray it off the most environmentally friendly option is to paint over it
Graffiti remover at Toolstation
Somebody beat me to it by taking a trip up today. Big shout out to the guys at the Pine Marten Bar and Scran.
Well done to who ever cleaned it up
My local council do that - a combination of lovely soft local sandstone and user error means the graffiti that was painted on the war memorial is now carved into the stone
