Removing silicon se...
[Closed] Removing silicon sealant
13 Users
The bath sealant has gone moldy and it seems is also leaking (water through the ceiling below), any tips for removing it?
It curls round the edge of the bath (out of sight) and so won't 'just' pull out if you grab a bit, so far I've been left to dig it out with a stanley knife which is extremely slow and tedious, so any tip to remove it would be great.
Posted : 03/12/2009 3:41 pm
you can get some 'silicone eater' stuff but it's not wonderfully effective, you'll still end up digging away a bit.
Posted : 03/12/2009 3:42 pm
 jedi
scalpel blade
Posted : 03/12/2009 3:43 pm
Didn't think there would be much that helped, but thought I'd best ask 1st, think I need to make a tool to help me remove it might be the best option.
Have been ignoring the mold because it's such a crappy job, but the leak has pushed the g/f patience too far
Posted : 03/12/2009 3:45 pm
I sympathise with you.
Mines gone the same, i really wonder in this world of high tech this and that why nobody can come up with a suitable way of sealing round a bath that does not rely on whats basically a posh type of glue.
Posted : 03/12/2009 3:46 pm
I foudn those scrapers they sell to get paint off glass good (stanley knife blade holder, basically) but the silicone eater is ok to soften it up a bit if you give it time to work.
Posted : 03/12/2009 3:47 pm
Run a layer of decorative tiles around the bath with loads of adhesive and grout. With or without one of those plastic seal things.
Posted : 03/12/2009 3:51 pm
You can buy sealing strips which do the same job as the sealant. no idea if they are good or mould resistant.
A real pain to remove fully. I use a sharp Stanley knife blade to scrape it all off, and a blunt scraper thing. The silicone eater didn't work for me - and it was 3x as much as the replacement sealant!
Posted : 03/12/2009 3:53 pm
 jedi
or use the credit card method
pay someone to do it! 🙂
Posted : 03/12/2009 3:55 pm
you can buy a plastic scraper for removing silicon sealant from b+q thats shaped to go in corners, did our shower cubicle with one and it worked ok, less than a fiver iirc
Posted : 03/12/2009 4:00 pm
😀 if I could afford that, I wouldn't have been asking (@ Jedi).
Hmm may have mouch @ B&Q on the way home then, cheers.
Posted : 03/12/2009 4:01 pm
some of this
http://www.ct1ltd.com/multisolve.html to remove the [b]old[/b]
http://www.ct1ltd.com/ct1.html this is magic can even be used under water
Posted : 03/12/2009 4:04 pm
After failing to scrape off some shower sealant I used silicone sealant remover from Wickes. Makes life a lot easier but don't get it on the hands unless you don't like your fingerprints!
Posted : 03/12/2009 4:05 pm
The bosch pmf 180e multi multi tool has a flexible blade for removing that sort of stuff.
Not tried it mind.
And when you replace the sealant, make sure you buy decent silicon stuff! Did mine with cheapo wilko's own brand sealant, which was very stiff and went mouldy very quickly, so had to repeat the entire process again with decent stuff.
Posted : 03/12/2009 4:08 pm
 jedi
Posted : 03/12/2009 4:28 pm
I used the standard Screwfix anti-mould stuff...its gone mouldy, BUT only where it got marked by dripping water when it was going off, looks like someone dug their fingernails into it.
Rest of it is pefectly white, think it only cost £3 as well 🙂 Been there a year now.
Posted : 03/12/2009 4:29 pm
