Nipping away for a night in the T6 is manageable, but for a few days I'd want a bit more storage space, so looking at rear boxes. Pretty much settled on Thule, but open to suggestions.
Also, my Scorpion Buzzrack is getting a bit tired. The obvious solution would be a Thule Easyfold 3 and bolt on Thule Onto 2. Won't be able to carry big bikes and cargo, but can get an add on that would cope with the gravel bike. All this gets on the north side of £1500 though.
The alternative is the Thule Onto 2 with it's own base and a separate new Buzzrack to be used as an either or. Much cheaper, but not (quite) as versatile and the all in one Onto is a bit bulkier when not in use - they both collapse down, but the base and frame aren't as compact. Anyone use any of these combo's and got feedback? Ta
I have a Buzzrack P10 cargo platform with 2x large storage boxes from Solent Plastic's (had the boxes for many years). The platform doesn't tilt but is easy to remove the vertical post (with the boxes already removed) if you need to access the boot.
Cheap and has worked well on some long roadtrips.
