"Cheese headed...
[Closed] "Cheese headed bolts"
7 Users
from my VW Beetle Haynes manual in the section on engine removal.
Are there official 'cheese headed bolts' or was one of their writers having a bad day?
Posted : 16/01/2009 11:54 am
Cheese headed usually means a round head with a slot for a flat screwdriver (I think).
Posted : 16/01/2009 11:55 am
Does it not just mean they are made of a soft material, so you should use a good quality socket to remove them?
Posted : 16/01/2009 11:56 am
Well, my reasoning was ok.. but [url= http://myword.info/sendword.php?ch_head_1-a ]defined here[/url]
Posted : 16/01/2009 11:57 am
Ah, I would have called it a set screw.
Posted : 16/01/2009 11:59 am
Cheese headed bolts are also what Shimano supply with their rotors.
Posted : 16/01/2009 12:10 pm
Set screws generally are fully threaded, right up including the head if it's a grub screw (designed to sink into the item and keep going).
Screws mate with an internal thread or make their own thread, bolts have a nut on the end.
Cheese headed - head looks like a full cheese - cyl with a slot
Different from socket head - an allen bolt/screw.
Posted : 16/01/2009 12:21 pm
grubscrew doesn't have a head?
Posted : 16/01/2009 1:01 pm
 WTF
Allen headed bolts are the new cheeseheads.
And your manual is perfectly correct.
HTH
Posted : 16/01/2009 2:00 pm
Badly articulated, that's what I meant by it being threaded "including the head". Woudlnt be much use having a threaded head if it wasnt the same diameter as the shaft, but it has to have a head or else it can't be driven - so to me the head is still present, its just the same diam as the shank 🙂
And actually everyone seems to be replacing allen headed bolts with damn Torx bolts. They are better but do confuse if you cant see the screw/bolt you're working on.
Posted : 16/01/2009 4:32 pm
