5 computers hooked into a LAN are only showing as 10mbps connection on the computer end and the switch end, where as the NAS and Printer are both showing 100mbps hooked into the same network.
Will the slow speed be likely down to the network cables on the computers (prob 7 years old Cat 5) or the Network Card on the computers? (although these are supposed to be gb Lan direct on the motherboard)
Some cheap switches can only support 10mbps FD if there are a number of devices plugged in. What happens if you plug just one in at a time?
Have you looked at the config for the NICs?
Not a cheap switch so thats not the issue, config on NIC has limited options. Thats on windows 7 / Vista drivers though. Drivers direct from Asus don't want to load.
Cat 5, no matter what age, will support 100Mb. That leaves the config both ends.
Both are likely set as auto-neg, so try setting one, or preferably both, to use 100Mb.
if the cards are set to autonegotiate, try manually setting them. Try 100 Mb/s half dup if full dup doesn't work.
If you can't, can you set the switch ports to 100 Mb/s? If one end is fixed, the other should follow if it can
cheers guys i'll have a play. I did try setting the nic to full dup 100 but it lcoked out. I'll try half dup or play with the switch
Either, both ends (switch and NIC) need to be set to auto-negotiate speed and duplex, or both ends need to be manually set.
If you have one fixed up and one on auto, it'll connect at 10mbps / half duplex (assuming it connects at all), which I suspect is your problem.
You can rule out cable faults easily enough - swap out the cable with the known-good one on the printer. Can't see it being than myself, but stranger things have happened.
Cougar is spot on. If you hardcode one end and not the other then it won't work. That may well be why your NIC locked up.
Switches, by definition, should be capable of full duplex so don't bother with half duplex. Hardcode both ends to be 100full and it should all work okay.
If you have Gb capability at BOTH ends, switch port and NIC, you should set both sides to Auto/Auto, that's the IEE standard, to get Gb.
If the NICs are Gb and the switch is 100/Full, you'll need to set both ends to be 100/Full as above.
Isn't this a slow network question? 🙂
That's very politically incorrect of you, we prefer the term "differently packetised" these days.
ok i've tried the above without success. The Switch is a netgear GS608 and is set to auto neg as standard and you can't change that. It is a GB switch though so should cope with all speeds. Its seems to be working fine for the printer and NAS at full GB just not on the NIC's (all the same motherboard).
Any other suggestions??? setting the NIC to full 100 just crashes the connection.
