Putting up shelves
[Closed] Putting up shelves
9 Users
If you were putting up a shelf in your garage that wasn't going to take much load, would you mount the brackets in mortar or avoid like the plague?
Posted : 27/01/2014 9:45 am
You need sky hooks m8.
Posted : 27/01/2014 9:47 am
Why mortar? If you have to drill you may as well drill into brick/block?
Posted : 27/01/2014 10:13 am
Avoid mortar. Shelves get loaded up over the years.
Posted : 27/01/2014 10:17 am
i cant work out what the reasons for mounting in mortar would be ....
mortar crumbles at the best of times - the last thing it needs is a hole in it ....
Posted : 27/01/2014 10:23 am
Depends what the garage is made of but usually use [url= http://www.screwfix.com/c/screws-nails-fixings/shield-anchor-bolt-type/cat840436 ]anchor bolts[/url] because as globalti wisely said
Posted : 27/01/2014 10:24 am
I have had problems with using anchor bolts in blocks. I never seem to be able to get a balance between a solid fixing and just breaking the block when I tighten the bolt.
May be just because I am pretty handless mind!
Posted : 27/01/2014 10:27 am
try - fischer hammer hit frame fixings
Holding up my world in the garage.
Posted : 27/01/2014 10:28 am
 grum
Mortar? 🙂
Posted : 27/01/2014 10:30 am
+1
Posted : 27/01/2014 12:13 pm
The prev owner has drilled mortar in a number of places and I didn't know why, didn't seem the best idea to me so I thought I'd check with the collective. Thanks all.
Posted : 29/01/2014 10:09 am
