Putting a cat flap ...
[Closed] Putting a cat flap in to a UPVC door
12 Users
Looking to put a cat flap in this door, but not sure how to do it...
The decorative pieces aren't stuck on, they are moulded into it
[img] ?oh=950bf15c3065f29c162c123d72aa0d94&oe=58C24BBD[/img]
What would STW do?
Trying to avoid drilling through the walls (done it before with a core bit at my sisters - very slow and messy)
All the windows in the house are double glazed too so can't go through them.
One suggestion would be to replace the door with a wooden one I guess. My pal lives by herself so some safety consideration there I guess
Posted : 29/11/2016 11:52 am
If the door is the same as ours the plastic bit in the middle can be replaced with a flat piece that can be easily cut with a jigsaw.
Posted : 29/11/2016 11:53 am
I fitted one in a uPVC door without drama, so it's certainly doable. It was a single panel though, not ridged like that.
Posted : 29/11/2016 11:54 am
As above - doors are modular, so you can replace the centre panel with a flat piece, a sheet of glass or whatever.
There will be some beading (most likely on the inside) that can be persuaded out - take the removed panel to a UPVC trade suppliers and they will sell you a replacement flat panel*.
*unless you live on a sink estate, in which case replace with a sheet of plywood.
Posted : 29/11/2016 11:56 am
Why can't your pal get up and let the cat in and out? We have two cats who are in and out all evening, which is a pain in the wotsit admittedly but it means that A - we have control of what cats enter our house and B - we don't have to destroy the integrity of the door. Apart from the evenings the cats are lazy and spend most of the day sleeping on a bed or a chair somewhere. They stay in at night.
Posted : 29/11/2016 11:58 am
As above - you can pick up the flat panels on ebay for relatively little cost.
Fit flap to new panel and then replace panel in door.
[url= http://www.ebay.co.uk/itm/White-UPVC-Flat-Door-Panel-20mm-24mm-28mm-Thick-Plastic-Infill-Foam-Filled-/371274958757?var=&hash=item5671b647a5:m:mufKOpODYZq3e63jR7MWTng ]uPVC panel[/url]
You'll need to know how thick the existing panel is before purchase.
Posted : 29/11/2016 11:59 am
You can get key-coded flaps which respond to a dongle on on the collar.
As above - we had our door & windows replaced a few years ago. We wanted to put a cat flap into one of the doors & it was actually in good condition, so we just chose a new skin that had a flat lower portion, rather than the mouldings shown in your image.
The skin will be upvc with a polystyrene core in all likelihood so you can just stick the template on, check it, measure it, check it again, re-measure, check once more, start cutting with a jigsaw, check again, finish cutting.....
The outside of our door now has quite a step down to the floor - too much for the cats to manage while negotiating the cat flap at the same time, so I've put a 'temporary' step in place (that's been 'temporary' for at least a couple of years now!!
We used one of those cat flaps that detects the cats microchips to lock out other cats. Took them a few days to get used to it, but it works extremely well.
EDIT - this one:
https://www.amazon.co.uk/SureFlap-Ltd-Microchip-Door--White/dp/B003EGIM3O/ref=sr_1_1?ie=UTF8&qid=1480420957&sr=8-1&keywords=microchip+cat+flap+sureflap
doesn't require a collar with a magnet or anything - just uses the microchip in the cats neck...
Posted : 29/11/2016 12:01 pm
don't forget mr tibbles!
also remember that uPVC doors usually have a metal sheet down the middle that borks those magnet-operated catflaps. They still open, but you have to tape down the locking mechanism. The microchip activated ones work fine tho.
It looks like an externally-beaded frame (assuming your pic is taken from inside) so the panel might be stuck to super-sticky security tape (although it looks like a rubber gasket on the pic). if it is tape then you'll need to cut the panel loose with a stanley blade around the tape. Over and over again. It's a right bugger to do.
I used to work in a factory where we manufactured pvc doors.
I also know that I can break into your house by simply removing the pvc panel from your shite front door 😉
Posted : 29/11/2016 12:05 pm
Posted : 29/11/2016 12:14 pm
She needs a cat flap cos she comes to stay at my house for a few days (we stay in different towns) at a time and her cats have murder-rages that must be fulfilled.
Good info on the door panels - I was not aware!
Posted : 29/11/2016 1:29 pm
Dunno about STW but on eBay you put them in the wall.
Posted : 29/11/2016 1:51 pm
Straight over the raised bits, with a raised flap?
p.s. don't forget to hook the thing up to the Internet https://twitter.com/DaphneFlap
Posted : 29/11/2016 8:02 pm
