Programmable replac...
[Closed] Programmable replacement garage remote controls
2 Users
Help!
I have an electric garage door and one of the remotes is on it's way out so I am looking to replace it so we always have a back up. However I have now bought (and returned) two remotes that claim to be programmable yet I have been unable to programme them despite following instructions to the letter.
Is there specific ways to programme certain ones (I have read about needing to send a signal from the receiver unit on some websites, but neither replacement I tried said I needed to do that).
If it helps the brand of the existing remote is 'Global' (I can't find any reference to that brand online however I have found a visually identical one here http://www.garage-door-remotes.co.uk/slavedor-sd1-prog.htm) and the system is 'DCS' (Dynamic Code System) as it says on the original box the existing remote came in. This makes me wonder if it is on a unique frequency and not on the 433mhz stated on the back which renders it impossible to programme a new one from?
Thank you for any help and advice received!
Posted : 16/06/2017 1:39 pm
Is yours a rolling code type?
If so you need to order a rolling code type
I have this one which learned both the rolling code of my garage opener as well as the fixed code of my garage alarm.
https://www.theelectricgateshop.co.uk/SICE-Why-Evo-Multi-Cloning-Remote
Posted : 16/06/2017 2:26 pm
I don't know if it is or isn't (I didn't have the door installed myself - it was already installed when we moved in) but this 'DCS' mentioned on the packaging suggests it may be. Is there any way of finding out if that is the case?
Posted : 16/06/2017 2:34 pm
