Problem upgrading o...
[Closed] Problem upgrading old PC
Trying to squeeze a bit more life out of an old PC. Its a Esprimo E5710. According to the spec it'll take 4GB but when I put two sticks of 2GB in it won't boot, I get 4 beeps which is apparently a memory error. Tried two different sets of RAM and its the same. Tried googling for anyone having a similar problem and get loads of links to shops selling RAM, all suggesting 4GB would be OK, 100% compatible, etc. Any ideas why its not working? BIOS up to date
[url= http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/professionalpc/ESPRIMO/E/EsprimoE5710.htm ]specs here[/url]
Posted : 01/07/2011 9:08 pm
it says this in the spec:
Max Memory 2GB* DDR2 (667/533) dual channel - 2 DIMM slots
Posted : 01/07/2011 9:19 pm
It also says in the spec...
*4GB with future 2GB memory modules
Posted : 01/07/2011 9:24 pm
motherboard pdf says you should be ok is the spec on the memory defiantly correct?
Technology DDR2 400 / 533 / 667 unbuffered DIMM modules 240-Pin; 1.8 V; 64 Bit
Total Size 256 Mbytes to 4 Gbytes
Module size 256, 512, 1024 or 2048 Mbytes for one module
With a memory con?guration of 4 Gbytes the visible and usable main memory can
be reduced down to 3 Gbytes (depending on the system con?guration).
You may use only unbuffered 1.8 V memory modules without ECC.
DDR2-memory modules must meet the PC2-4200U, PC2-5300U
or PC2-3200 speci?cation.
Posted : 01/07/2011 9:27 pm
ah I didn't spot that. There's a reason I'm a programmer not a technical bod ๐Ÿ˜‰
Posted : 01/07/2011 9:50 pm
I think its this
The spare RAM I've got is 5300P. Oh well thought it might be quick and cheap. Anybody want to swap 2x2GB of DDR2 5300P for some 5300U?
Posted : 01/07/2011 9:54 pm
