Preparing computer ...
[Closed] Preparing computer (imac) before taking in for repair....
Advice sought for where stuff's hidden that I need to delete.
I know where the firefox password file is.
Any other gems ? It's been used for our life for 3 years.
Thanks
I should be able to get at everything - the problem is that it runs for a couple of hours then just drops. So, I'll be taking to to the 'genius bar'...
Posted : 15/02/2016 4:34 pm
Gary? .....is that you? ๐Ÿ™‚ ๐Ÿ˜‰
Posted : 15/02/2016 4:36 pm
[url= https://support.apple.com/en-us/HT201857 ]https://support.apple.com/en-us/HT201857[/url]
Posted : 15/02/2016 4:41 pm
Thanks, gobuchul. Hoping not to need to erase the disc as I hope to be able to leave apps and utilities on to save time when it's fixed...or am I being naive and should erase ?
perchy, my wife's the main user, there may be ridiculous quantities of shoe images...hopefully nothing worse.
Posted : 15/02/2016 4:45 pm
What needs repairing? Can you not just take the HDD out and keep it at home? They should be able to boot it with a spare if they need to do that.
If you do need to kill the disk, 'shred' should work (if you have Mac Ports installed), as should 'dd if=/dev/null of=/dev/disk1' from the command line/terminal.
Leave a fair bit of time for the two to work.
Posted : 15/02/2016 4:55 pm
willard, taking a modern imac apart is beyond me. Sadly, it ain't like an old PC. I'm hoping it's the power supply. If I could get it apart to get at the hard drive I'd do the psu at the same time...
Posted : 15/02/2016 4:58 pm
"Can you not just take the HDD out and keep it at home"
No is the simple answer .
On the smaller ones you can't even access the RAM . The newer ones are glued together and are a nightmare to get inside . At least on the 27" version the user can access and change/upgrade the RAM
Back it up and then back it up again .
Posted : 15/02/2016 5:01 pm
Have you a spare hard disk? Clone the original to the spare and then erase the iMac disk. You can then clone the mess back in when it all returns from repair.
Posted : 15/02/2016 10:30 pm
