Posts for a hammock...
[Closed] Posts for a hammock (structure help)
In anticipation of another gorgeous summer, I'm planning on sticking a couple of posts in the ground to hang a hammock between.
Two 4x4" posts dug in 3-3.5m apart. Will add concrete mix, and will also be using a round pole to act as a brace between the two posts at the top.
A bit like this:
Question is, will 3m posts be long enough given that they have to stand at just over head height?
Is 2/3 above ground and 1/3 dug in adequate? (given that the horizontal pole should act to stop the posts from falling in)
Edit: Forgot to mention soil is clay rather than sandy.
Posted : 17/03/2013 9:41 pm
Ok, the attempt at a diagram didn't quite work ๐Ÿ™‚
Posted : 17/03/2013 9:42 pm
wouldnt something like this nit be better?
Posted : 17/03/2013 9:43 pm
It's going on an allotment hence using posts in which will have karabiner hooks for the hammock.
Above stand would be nice, but can't afford the footprint!
Posted : 17/03/2013 9:47 pm
If you sink a 4x4 3m post 1 m into the ground in clay and concrete it in I can almost guarantee it won't move **** all.
Posted : 17/03/2013 10:06 pm
Ditto
10ft post 3 ft under
Solid as a rock
Posted : 17/03/2013 10:08 pm
Jolsa - I mad my own pair of these out of some ally bar lying around. Matched with some carabiners it makes adjusting the hammock for sag and pre-load a doddle!
http://www.ebay.co.uk/itm/320872909241
Posted : 17/03/2013 10:10 pm
before you use concrete check your tenancy agreement first
Posted : 17/03/2013 10:11 pm
you dont necessarily need to use concrete. well tamped back fill of small stone/gravel/sand will do the job.
Posted : 17/03/2013 10:13 pm
 joat
At that depth, as long as the clay is dryish (i.e. you can't get all 'Ghost' with it) it will be strong enough, just back fill and tamp a little at a time.
Posted : 17/03/2013 10:22 pm
Thanks all for the comments, good to hear.
Stoner, the Amazonas fixings are what I'll probably be getting (it's an Amazonas Barbados hammock). Either the Easy+ or Smartropes similar to the sort you've made.
http://www.amazonas.eu/en/accessories.html
Just need to figure out whether I need the flexibility of the Smartrope or whether the Easy+ onto the posts will do given the space I'm working in.
May reconsider the concrete use, possibly overkill given that I'm using a horizontal pole to counteract the posts being pulled inwards.
Posted : 17/03/2013 10:31 pm
A small amount or type 1 ( hardcore ) tamped around the posts enough to fill the holes will stop any movement as stoner said. Make sure any backfill aggregate is angular.
ps. You can't successfully tamp/ compress wet soil or clay.
Posted : 18/03/2013 1:12 am
You need damned strong posts, the leverage is mental.
I use posts but have guy lines off the back, going through a mental eye bolt thing at the top of the post and then attach the hammock with carabiners.
Or use a horizontal post as you say.
Posted : 18/03/2013 1:15 am
