Polyfilla - which o...
[Closed] Polyfilla - which one?
5 Users
Seems to be loads to choose from - I have a couple of areas of broken plaster, quite deep in places - just want an easy repair, doesn't need to be cosmetically perfect
Posted : 24/09/2012 10:01 pm
http://www.duluxdecoratorcentre.co.uk/servlet/ProductHandler?code=DDC10171
Posted : 24/09/2012 10:03 pm
Don't use ready mix stuff, its rubbish. Sets inconsistently, sometimes very hard to sand etc.
I always use this http://www.screwfix.com/p/polycell-polyfilla-trade-interior-filler-2kg/36426
They also make a version that can be used externally
Posted : 25/09/2012 7:23 am
What are you doing with it? Ive never had a problem. It works into a consistent paste easily, wont sag or bulge even in deep fills. Its not great on the thinnest skims though - can tend to look scored.
Posted : 25/09/2012 7:26 am
The One Fill is excellent for smallish holes/cracks, I use it on woodwork exclusively. It can take a lot of covering on walls and ceilings - it shows through emulsion. Easifil for under emulsion if there's alot of filling, 2 aplications on deep stuff though
Posted : 25/09/2012 8:20 am
I use the wickes pre-mix decorative one - very light and sands down easily. No shrinkage and dries quick too.
Proper polyfilla just seems overkill for most situations it's about 5 times denser than the plaster you're putting it onto and takes and age to sand back to flat.
Posted : 25/09/2012 8:23 am
