any recommendations? to fit canon
round
Circular.
Circular
& flat
Is it for a autofocus or manual focus system?
Hoya do a good range of screw in filters
B+W are the bling choice 😉
Not so flat they don't have a screw thread, though.
in case you thought 'circular' was being facetious, it doesn't refer to the shape, but the type- there are two types, linear and circular- linear doesn't work too hot on slrs - not much chance you'd get sold one though.
flat [b]glass[/b]
unflat unglass
[url= http://www.7dayshop.com/catalog/product_info.php?cPath=777_1&products_id=70148 ]this[/url] in a p-sized holder from 7dayshop.com
simonfbarnes - MemberNot so flat they don't have a screw thread,
flat glass
unflat unglass
not strictly true though, is it Simon- old windows being a case in point
autofocus bog standard EF-S 18-55mm lens
'linear' polarisers don't work well with AF systems, 'circular' is what you need
Yep, have a nose for a circular polariser
Think you need a 58mm thread, will tell you on the back of the lens cap 😉
I would push the boat out and get either a Lee or Cokin Z Pro holder and filter.... will cost you somewhere north of £200, but it gives more flexability going ahead (screw in filters just started pissing me off as I would want to throw in an ND Grad too)
It also means that you only need to buy 1 filter rather than replicate it for every lens!
Just watch out for the vignetting on wide angle lenses using square filter systems 😉
Don't get it on the square filters at 17mm (full frame) using the Z Pro, so long as I reverse the holder. The polerizer does cause some vignetting at that focal length, but push it up a bit (around 18 - 19mm I think) and there is no issue at all!) That should allow you a 10mm-11mm focal length on a crop sensor 😉
oof £200 how about £15.48 😉
[url= http://cgi.ebay.co.uk/Hoya-58mm-Circular-Polarizing-Polarizer-Filter-UK-STOCK_W0QQitemZ200310381084QQcmdZViewItemQQptZUK_CamerasPhoto_CameraAccessories_CameraLensesFilters_JN?hash=item200310381084&_trksid=p3286.c0.m14&_trkparms=72%3A1690%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 ]cheap and nasty?[/url]
hoya ultra thin if you are using an 18mm lens otherwise you'll get vignetting.
the story about old windows being thicker at the bottom due to flow is apocryphal - it's just that the glass used to be cast that way...
simonfbarnes - Membernot strictly true though, is it Simon- old windows being a case in point
Thanks Simon. Tossed in the urban myth pile.
If you're buying one - consider my recent good luck at Jessops, and perhaps with some cunning you may be able to instigate a similar experience:
- Jessop's own 67mm cir-polarising filter is about 35% cheaper than a Hoya one; so being poor - i went in asking for one.
- They didn't have it
- The salesman told me that they did have a Hoya one, and that it was their policy to sell the next cheapest available option to people for the same price if their own brand was not in stock
- I walk out of the shop with a £62 Hoya green series filter for £40
BTW - i run this on a Nikkor 18-135mm lens and do not suffer vignetting even at 18mm.
Good luck. A Polariser is the best thing you can add to your SLR.
circular P-series filter. You buy one filter and then adaptors for each lens you want to use it with, saves you a fortune. I have a circular poloriser and some grad filters which all fit in the same adaptors and on any of my lenses. It's a little bit of a faff fitting them but it's well worth the saving.
Wot Samuri said (I have the same)
I've got the P-series filter system and to be honest, find it such an arse that for most photo stuff I can't be bothered with it. I do get the ND grads out though sometimes.
For polarising duties, I've got a Hoya, which does the job.
" mrmichaelwright - Member
hoya ultra thin if you are using an 18mm lens otherwise you'll get vignetting. "
Is that 18mm on a FF sensor?
I use a Hoya green circ polariser on a Canon 17-85 on a crop sensor and get no vignetting at 17mm, but if there is a UV filter between the polariser and the lens then a little vignetting is noticable. Just have to remember to take the UV filetr off.
You mean like this one? (£16 on eBay):
what difference does the 'green' part make? better colours of landscape as opposed to sky?
I don't think it is actually green. Just a branding / quality-level thing.
'green' as in the colour of the paper card inside the packageing is the basic model. I think the Hoya 'Pro' is the more fancy model.
The green one I got works just fine. Unless you're on L series lenses then I can't see the point in really expensive filters.
try kerso on ebay, he's quite competitive on filters and stuff like that
