plane on a conveyer...
[Closed] plane on a conveyerbelt
[#3941953]
it's a slow day in the office, anyone got a link to the stw dweeb fest par excellence ?
can't find it in the search.
Posted : 04/05/2012 9:43 am
It won't 😉
Posted : 04/05/2012 9:45 am
Picolax is funnier
Posted : 04/05/2012 9:46 am
All you need to know is that it will 😆
Posted : 04/05/2012 9:47 am
i need to know the conditions involved. is it a big long runway sized conveyer belt or is it on a treadmill ?
Posted : 04/05/2012 9:50 am
Doesn't matter really. On a short treadmill it will move forward, fall off the end and then take off as normal.
On a long runway sized treadmill it will move forward and take off as normal.
(amazingly some people still don't get this 😯 )
Posted : 04/05/2012 9:52 am
Thinking about it. The best way to solve this one is to lobby the government so that Heathrow Runway 3 is built as a massive conveyor belt. That would settle it once and for all.
Posted : 04/05/2012 9:54 am
[img] ?w=640&h=415[/img]
I think the original thread was lost years ago.
Posted : 04/05/2012 10:04 am
I think it has been discussed on pretty much every chat forum on the internet at some point or other - google should provide a few good snippets 😀
Posted : 04/05/2012 10:14 am
 SST
Badger badger badger badger . . . .
best thread ever!
Posted : 04/05/2012 10:16 am
 Muke
Baby Robin on a conveyor belt ?
Posted : 04/05/2012 10:25 am
Posted : 04/05/2012 10:50 am
Now thats funny.
Posted : 04/05/2012 10:52 am
Mythbusters busted it:
[url=
on a conveyor belt[/url]
Case closed
Posted : 04/05/2012 10:53 am
I can't believe the pilot in that Mythbusters video thought it wouldn't work 😯
You'd hope that pilots would have a better understand of how planes fly!
Posted : 04/05/2012 11:05 am
GrahamS - Why? I have been using computers for a living for years and other than basic stuff about how they work I'd be in no more position to explain how they really work than the next man. My best guess is magic.
That said I do know how planes fly and why the "discussion" is so comically stupid so perhaps it's a shit analogy
Posted : 04/05/2012 11:33 am
Well yeah - I don't expect pilots to be aerospace engineers - but I had [i]hoped[/i] they'd understand fairly rudimentary principles of flight. 😆
Posted : 04/05/2012 12:18 pm
The mythbusters experiment doesn't really match the true "spirit" of the plane on a conveyer question though as the conveyer is undergoing travel in a direction (rather than being stationary but rotating)
Air movement in and around the wings generates lift, so if the plane is moving, because the conveyer is, as in the mythbusters experiment, if you're lucky, at some point, lift is greater than gravity, and the plane will take off.
The proper test should be when the plane is on a stationary but still rotating conveyer... 😉
Posted : 04/05/2012 12:26 pm
You don't understand this, do you?
Posted : 04/05/2012 12:29 pm
I included the 😉 ....
Make of that what you will :mrgreen:
Posted : 04/05/2012 12:31 pm
I can answer this.
No matter if the plane is on a treadmill, Swiss ball or excerise bike. It'll only take off if its moving. Or it's very, very windy. 🙂
Posted : 04/05/2012 12:32 pm
Posted : 04/05/2012 12:33 pm
 emsz
What's this about?
Posted : 04/05/2012 12:35 pm
What's this about?
Trust me. You [i]really[/i] don't want to know.
Posted : 04/05/2012 12:36 pm
GrahamS
"The proper test should be when the plane is on a stationary but still rotating conveyer... "
Eek! Worded that badly.... The proper test should be when the plane is on a conveyer that is stationary relative to the earth, but the belt on which the plane is sitting on is still rotating... 😉
Posted : 04/05/2012 12:38 pm
Posted : 04/05/2012 12:42 pm
what if a delorean was on a treadmill that was doing 88mph?
Posted : 04/05/2012 12:43 pm
Pilot was 100% correct - test protocol was 100% incompetent!
Posted : 04/05/2012 1:01 pm
Explain (or refer to meme above ^^)
Posted : 04/05/2012 1:09 pm
Easiest way to explain - what do you think would have happened to the aircraft's position in relation to a specfic point on the ground if the pilot had not fired up the engine as the car accelerated?
Posted : 04/05/2012 1:16 pm
Well it would have moved backwards with the tarp, though probably at a slower speed than the tarp.
Posted : 04/05/2012 1:22 pm
Why so? (once you take the initial inertia out of the equation).
Posted : 04/05/2012 1:38 pm
Do we know if the flux capacitor drives the wheels or generates thrust?
Posted : 04/05/2012 1:44 pm
the new aircraft carriers...can't they be fitted with with conveyor belts instead of catapults
Posted : 04/05/2012 1:46 pm
well the speedo was linked to the wheels in the delorean... so that would suggest maybe wheel speed/revs was enough?
ahhh but then in like BTTF 3 it flies...
shame.
Posted : 04/05/2012 1:48 pm
Are you sure?
shame
Doesn't it fly at the end of the first film - though admittedly this is when it has returned to the present from the future (that is to say once it had the hovering wheels upgrade)
Posted : 04/05/2012 1:51 pm
Tarp Direction: <----
Forces acting <---- are pulling the plane by the base of its wheels. Wheels can spin freely.
Forces resisting this, acting only on the plane, are inertia (as you said) plus I would suppose some [i]slight[/i] drag from wind resistance, increasing with speed.
Forces <--- are obviously far greater than forces -->, but forces -> are only acting on the plane, so it has less total force acting in <- than the tarp and is free to spin its wheels.
Still don't see how this helps your argument.
Posted : 04/05/2012 1:54 pm
yeh im sure its wheel speed based. speedo drive goes the centre of the hub.
shame tho, the flying has wrecked it.
Posted : 04/05/2012 1:55 pm
Baby Robin on a conveyor belt?
Tried that one. It just falls out of the sky when it reaches the end of the conveyor belt......
Oh is the scene where they repair the speedo only in the directors cut?
That bloody Doc Emmett Brown; being all good at inventing stuff
Posted : 04/05/2012 1:59 pm
So if the conveyor belt is moving at 25mph in this case, what speed would the plane be moving backward in your estimation with the engine turned off?
Next question. Are you agreed that the plane would have to apply some thrust to prevent it from going backwards in relation to a fixed point on the ground whilst on the conveyor belt (but not necessarily to actually move forwards in relation to a fixed point on the ground)?
Posted : 04/05/2012 2:01 pm
I dunno - lets say 24mph for arguments sake?
Yep.
Posted : 04/05/2012 2:06 pm
Posted : 04/05/2012 2:09 pm
