Painting a heating ...
[Closed] Painting a heating oil tank
6 Users
I know there's a few manly men on here, so...
The tank has a bit of surface rust so I guess will need wire brushing, sanding, priming and painting? I'm looking for suggestions as to what primer and paint would be best.
Ta much.
Posted : 19/03/2014 2:23 pm
hammerite/smoothrite? or that boat paint, Toplac I think it's called
Posted : 19/03/2014 2:31 pm
Zinc based primer to keep rust at bay (or Hammerite).
Posted : 19/03/2014 2:36 pm
Thanks chaps.
Hammerite sprung to my mind at first. Perhaps I've been over thinking it. I thought perhaps there was a a special paint that the tank makers used, since they are all the same horrible green...
Posted : 19/03/2014 2:42 pm
If you use hammerite you may have to remove any powerdcoating that's there first. The xylene (is it still this?) thinners in hammerite will turn it to a peely-crispy goo otherwise.
Posted : 19/03/2014 2:55 pm
Thanks, will bear that in mind.
Posted : 19/03/2014 3:12 pm
Like this?
Posted : 19/03/2014 3:14 pm
http://www.por15.com/
Posted : 19/03/2014 3:15 pm
