Paging Stihl chains...
[Closed] Paging Stihl chainsawists.
I've just fitted a new chain, bar and sprocket to my little ms210, but there seems to be a problem with the oiling.
The system works fine and pump oil out readily, but once I fit the bar and chain more oil drips straight out of the bottom of the saw than lubes the chain. It fails the fling test but passes the pissing out the bottom test.
Any ideas. The bar seems to be sitting flush with the hole and I can't see how oil isn't being driven into the port on the bar.
Posted : 21/10/2014 7:08 pm
Can you get some pictures of the saw and bar and without the bar on the saw
Posted : 21/10/2014 7:18 pm
I'm sure you've cleaned the bar of all muck including the oil holes!
What flip says. Oil hole blocked or bar groove blocked. Perhaps it's the wrong bar and the oil hole doesn't line up?
Posted : 21/10/2014 9:02 pm
ditto flip.
When swapping chains, flip the bar over, clean the chain guide and file any burs, and clean the oil ports.
Posted : 21/10/2014 9:07 pm
Everything is brand spanking new.
Posted : 21/10/2014 9:15 pm
ah. maybe check the oil ports for machining errors (blind gallery)
Double check you really have installed it correctly.
triple check its the right model bar ๐Ÿ˜‰
Posted : 21/10/2014 9:21 pm
Not a regular Stihl user, but common to a lot of stuff, depending on construction, the sprocket/clutch assembly also drives a worm gear for the oil pump. Check that it is there, engaged and not stripped.
Posted : 21/10/2014 9:23 pm
^ Id be surprised if that was knackered, but if its pissing out at the bar end then the wormpump is probably OK.
It has a funny little wire that sits in a notch in the clutch. Seems the wierdest mechanical idea, but also seems to work, more or less.
Beats dipping your tip in a paint tin of oil ๐Ÿ™‚
Posted : 21/10/2014 9:25 pm
OP, do you still have the old bar? Have you tried refitting and seeing if the oil is getting through to pass the fling test.
Posted : 21/10/2014 9:31 pm
My mistake, speed read no oil flow, common for high use/old saws to wear out their pumps.
Check the filter and pipework from tank to outlet.
As mentioned above, test with old bar to benchmark.
Posted : 21/10/2014 9:51 pm
Bit of sh&t/ sawdust/ metal filing trapped between bar and saw meaning bar not sealed against saw and oil taking the easiest route.
Posted : 21/10/2014 10:05 pm
My money seems to be on the front non adjustable bolt sitting slightly proud of the plastic and allowing a slight amount of gap.
[img] ?v=1283198908[/img]
rocking on the metal collar of the front bolt. Now how does one tighten those up...
Posted : 22/10/2014 12:26 am
But it didn't do it on the old bar did it? Which means it's something to do with the new one not the fixed stud.
Posted : 22/10/2014 8:11 am
It may have done it and I'd never noticed.
It's had a new sharp end as I leant it to someone who ran it dry.
Posted : 22/10/2014 12:46 pm
