One for the runners...
[Closed] One for the runners - why the numb feet?
 Crag
So, new year, new fitness regime! With 2011 being the year I get fit (honest) I've entered the Leeds half marathonamd have been running 3 or 4 miles 3 times a week.
Trouble is, I'm getting numb feet about a mile in. if I walk a couple of paces I can feel the blood flowing back and feeling return - obviously no good if I'm running 13 miles. Any ideas why it's happening, and more importantly, how do I stop it.
Posted : 16/01/2011 10:51 pm
Try some different, or properly fitted shoes. Or get some roller skates.
Posted : 16/01/2011 10:52 pm
The shoes might be constricting your blood flow a bit when they flex as you run. Try loosing the laces a bit, and if that helps, try some different lacing patterns.
Posted : 16/01/2011 10:55 pm
 Crag
Laces nice and loose. Is it a case of runnIng conditioning that I just to suck up and wait till I'm the epitome of athleticism?
Posted : 16/01/2011 11:02 pm
I guess another thing to do is to ascertain whether the numbness is poor circulation or a nerve sending a false signal. So maybe next time they feel numb, take your shows and socks off and check if your feet are actually cold. That way at least you'll have a bit more info to go with.
I'd be also inclined to just try some different shoes.
Posted : 16/01/2011 11:22 pm
used to suffer from the same thing, always after about 5 miles on every run. Eventually read on runners world that short achilles tendons can cause it. Did achilles stretches before each run (standing on tip toes) and the problem stopped - give it a go.
Posted : 17/01/2011 12:18 am
 Crag
Thanks for replies, new shoes and achilles stretches it is then.
Posted : 17/01/2011 2:36 pm
6 replies in and nobody's shouting about barefoot running yet? Where are the usual suspects?
Seriously, though, properly fitted shoes and stretches should help. And good luck in the Leeds half. Practice running up Stonegate road to get used to it; that's the hardest part of the course.
Posted : 17/01/2011 2:42 pm
BAREFOOT RUNNING!!!!! HTH
And... yerallpussiesandgeekscosyoudon'tagreewithmeandyoucan'trunandI'mafantasticsurfer/driver/etc
Just in case anyone was missing the full experience ๐Ÿ™‚
Posted : 17/01/2011 2:52 pm
I think you missed out expert bare knuckle kung fu fighter, or whatever it was.
Posted : 17/01/2011 2:56 pm
Assume you got your shoes from a shop wear the film your running on a treadmill or watch you run down the street?
Posted : 17/01/2011 3:01 pm
attach many helium balloons to your arse, that should reduce the load & impact and in turn ease the pressure upon your feet.
Posted : 17/01/2011 3:08 pm
English translation service supplied:
[i]Did you get your shoes from a shop where they film you running on a treadmill or watch you run down the street?[/i]
Posted : 17/01/2011 3:12 pm
Don't go and buy new trainers straight away!
Stretch as above before deciding you NEED new trainers and warm up properly... or do you just want to buy new trainers.
Posted : 17/01/2011 3:45 pm
I find that my feet go a bit numb running barefoot this time of year as well.....Ho hum ๐Ÿ˜€
Posted : 17/01/2011 6:02 pm
Is there a specific part where the numbness starts or lingers?
Also, just to add to the stretching advice above, standing on your toes won't fully stretch your achilles.
The stretch is to find a small step or curb and stand on the edge of it with your heels hanging over, in the air but keeping your feet horizontal. Gently lower your heels, so they are lower than your toes, while keeping your toes on the step, and go back to the horizontal. Then raise your heel above the toes, and go back to the horizontal. Be gentle and patient as it can take ages to recover from achilles damage or to make notice any improvements.
If this is the cause of your problem, then it might also be worth stretching your feet, all the back of your legs including your bum and lower back too, as these areas all work together and could help.
Posted : 17/01/2011 7:01 pm
 dobo
narrow trainers made my feet generally ache, luckily my road trainers ere good fit so knew it was trainer related. that said i used to get serious pain in my calves, which was a combo of not warming up, not enough stretching and not used to running after long time off and only cycling.
just need to sort out my aching knee now which i think is bike related.
Posted : 17/01/2011 9:43 pm
