Novice Go-Pro/DSLR ...
[Closed] Novice Go-Pro/DSLR question for you photographer types.
Evening all
Planning a wee shoot using a Go-Pro (Hero 2 HD) for onboard and a DSLR for the rest. Anything in particular I should consider settings wise for each camera to ease compatibility/look between the two sets of footage when editing?
Thanks
Posted : 27/04/2013 8:26 pm
Make sure the framerate is the same across both cameras (or at least try and make sure that the Hero framerate is a multiple of the DSLR). And possibly resolution as well, depending on the capabilities of your DSLR.
Although the Hero2 *can* shoot 1080 at 25 fps, I personally find better results with 720p at 50 fps, less rolling shutter that way.
Posted : 27/04/2013 8:42 pm
What will you be shooting? The DSLR is going to look very different to the GoPro, even if only because of the difference in lenses.
Posted : 27/04/2013 8:50 pm
Cheers for the advice fellas.
Fairly typical bit of Scottish single track (ie dark), nothing particularly original. I'm expecting a different look between the cameras, and GoPro will be used minimally.
Posted : 27/04/2013 9:30 pm
If you colour/grade/stylise the GoPro footage to look obviously different from the DSLR stuff then you can make a feature of it and get away with the camera difference that way perhaps?
What are you editing with?
Posted : 28/04/2013 9:08 am
The most obvious thing is to match aspect ratios
Posted : 28/04/2013 9:19 am
I'm using Sony Movie Studio Platinum.
Had a first attempt with the SLR only today. Do you reckon it's too much ISO that's causing it to look a bit bleached? Bog standard iPad iMovie editor app, so that probably hasn't helped.
Posted : 28/04/2013 9:40 pm
