Not putting the hea...
Not putting the heating on - how's it going...?
Below 50-55 and you ar risking nasty things building up in the pipework.
The CH circulation water will be full of Fernox etc (or rust) and as it's a closed system, it's pretty mute if something wants to grow in there - you're never in contact with it.
Which reminds me, can't recall when I last topped up the Fernox....
Posted : 13/10/2022 5:39 pm
same here – did you also get the pdf file that showed you were now going to be paying even less per kwh than before – i really can’t figure that out!
Yes I think this is the key - they've worked out new KWH rates based on current prices minus the gov discount. So we'll now be charged the new discounted rates, which extrapolated out to historic usage has lowered the DD. If my thinking I right, this leaves more of our credit available for later in the winter period e.g. Jan - Mar when we'll really need it.
Posted : 13/10/2022 5:40 pm
The hot water just came on. No-one's had a shower so it's still a fairly warm tank in the lifecycle of hot water. The boiler outflow temp was at about 50 and the burner shut off, and I thought that was a bit cold for the hot water heating so I put it up one notch. It came on full then as the outflow temp approached 56 it throttled way back and it settled at 62/56. That's a fairly small temperature differential.
The burner turned off but the water was still circulating as the temps had dropped tou 49/48. So I nudged the thermostat to make that the shut-off temp. Water in the tap is now 49. That seems a reasonable level.
Posted : 13/10/2022 6:07 pm
I've calculated I lose about £2.50 worth of heat through the garage door, which is already insulated. I can probably reduce it by half for about £30, or nearly eliminate it for about £150...
Posted : 21/10/2022 10:24 am
It is warmer outside my house than inside at the moment during the day.
I'm getting close to lighting the fire. I've not had the central heating on yet.
Posted : 21/10/2022 10:32 am
Other than the 'height' of summer, for NE England coast, this is extremely common in our house. I've often wondered why.
Posted : 21/10/2022 10:36 am
Other than the ‘height’ of summer, for NE England coast, this is extremely common in our house. I’ve often wondered why.
Because insulation works both ways. Your house loses heat slowly during the night, and outside the sun warms the air quickly but that heat takes time to get into the house because you've insulated it.
Posted : 21/10/2022 11:09 am
So I am still sticking with my original plan with a slight tweak or two.
Originally I had it set to 16 degrees overnight and 18 degrees from 8am to 11pm. It would come on in the morning and maybe for a minute or two late evening. I've now changed that to be 17 degrees from 7.30 to 10am then up to 18 for the remaining day. Mainly so I can enjoy the feeling of warmth a second time in the day.
Posted : 21/10/2022 11:21 am
I’m getting close to lighting the fire. I’ve not had the central heating on yet.
We've not had the CH on yet but we did have the first fire of the year on Wednesday but that was just because my wife and daughter had been in a damp stables/field for several hours and were a bit chilly. By the end of the night, despite the fire being on as low as possible, it was uncomfortably hot.
Posted : 21/10/2022 11:42 am
Well, my cats are less than happy, even though I've had the fire on a few times.
Thermostat currently set to 17, don't think it's kicked in yet.
Posted : 21/10/2022 11:54 am
Still 18° in the SE, same forecast for all of next week too. Never known anything like it this late in the year! I'm still in shorts 😃 House is still 18-19° naturally in all rooms at the moment, no question of putting the heating on yet! (Admittedly last year the thermostat would've been set for 20° in the evenings but given we're economising now just got a blanket for the sofa & it's fine 😃)
Posted : 21/10/2022 12:23 pm
Unless it's proper pissing it down just open the doors and windows during the hottest part of the day.
Posted : 21/10/2022 12:35 pm
I'm pondering quite how leaky my oven might be, I know the door seal is a bit rubbish as the manufacturer doesn't seem to make one anymore, and the pattern ones are about twice as thick so I'm not 100% sure it seals at the top lip. It's also a gas oven so has a constant draught through it for the burner.
Also wondering how much is 'lost' from the boiler and it's pipework as it's now open to the hallway after demolishing the under stairs cupboard.
The heating isn't on, but the house definitely isn't cold yet.
Daytime temps still hovering around 15C too this week, which seems ridiculously mild?
Posted : 21/10/2022 12:46 pm
Also wondering how much is ‘lost’ from the boiler and it’s pipework
I too am wondering this. We have a hot water tank, the pipes leaving it act as heatsinks. As much DIY as I've now done I think I could open up the pipe boxes in the corners of the rooms and stick some insulation on.
Currently annoyed with. Annoyed with my boiler ATM - on a low setting whilst heating up hot water it will run until the outflow reaches say 62C or whatever then switch off, continuing to circulate the hot water to heat the tank. Fine, because the returning water is at say 56C. But when the temp drops down to 48 or so it won't turn back on and continues to pump the now lukewarm water around the circuit which is actually cooling my tank.
I think I'll have to set it to run only once per day, thus ensuring the tank is cooler and it can extract more heat from the circulating water and ensuring the return flow temp is low enough to allow condensing.
Posted : 21/10/2022 12:54 pm
Doesn't your tank have zone valves on.
Posted : 21/10/2022 1:02 pm
Yes, to activate either the heating or the hot water. But the problem is that I am trying to turn the boiler down as low as possible for better efficiency particularly with heating, when it ends up coming on. But heating the hot water only drops the flow temps about 6C. So if the boiler output temp goes above 63C then the return flow temp goes above 57C and it's not condensing any more.
I can set the outflow temperature to 63C, but burner cannot go below 9kW so when it reaches that temp it shuts off and the water keeps flowing - which is fine, it'll keep heating the tank with the water in circulation. The temperatures continue to drop of course as the water in the circuit cools. But it won't turn back on again until the flow temp is really low, 45C or so. At which point the flowing water is now slightly cooling the hot water tank.
Posted : 21/10/2022 1:17 pm
Still going here in Exeter, although it has been pretty mild. It's certainly warmer outside than in the north facing room i use for work so primaloft slippers and gilet are on.
Some form of exercise, either a run or ride at lunchtime tops up the body warm till the kids are back from school and i forget about being cold.
Posted : 21/10/2022 1:26 pm
Had to put the heating on last night. Kids came home from school soaking wet and shoes and coats wouldn't have dried otherwise.
Posted : 21/10/2022 1:34 pm
So if the boiler output temp goes above 63C then the return flow temp goes above 57C and it’s not condensing any more.
So your trying to make it work in its optimised zone on a system it's not optimised to work on. What happens when you want to use the heating as designed ?
Posted : 21/10/2022 2:03 pm
read this. thought of here…
It was rightly slated in the letters section the next day.
https://www.theguardian.com/business/2022/oct/19/why-do-we-keep-the-central-heating-off-it-isnt-a-thriftifarian-pose
Posted : 21/10/2022 4:52 pm
Whoever Julian Baggini is, I want to punch him in the face. For most people in this country a £2K increase in living costs in one year can't just be soaked up. He is underestimating just how many people are being hit hard this year, after years of incomes decreasing in real terms before the problems of 2022 hit.
Posted : 21/10/2022 4:56 pm
Had to put the heating on last night. Kids came home from school soaking wet and shoes and coats wouldn’t have dried otherwise.
That's my biggest challenge... but at least I have a bathroom with a extractor and a fan heater. Not had to resort to it yet but all my riding gear is still wet so it may well get used tonight.
Posted : 21/10/2022 5:34 pm
So your trying to make it work in its optimised zone on a system it’s not optimised to work on. What happens when you want to use the heating as designed ?
Yes I'm trying to make it work as efficiently as I can. I haven't tried measuring the temps with the heating on yet.
I have discovered that turning the knob on the front down doesn't reduce the burner, it reduces the target temp it heats to - so it still runs full blast until it gets close to that temp then it slows and eventually stops. If the load is enough, it can continue to run at that lower temp in a steady state - but there's never a steady state. There really isn't a lot I can do with this system, I don't think.
Posted : 21/10/2022 5:40 pm
Yes I’m trying to make it work as efficiently as I can. I haven’t tried measuring the temps with the heating on yet.
Well your not really Your trying to set it to a very specific set of circumstances.
How ever it's probably where the myth that it's cheaper to leave your heating on all the time is borne. Because it takes 7days to get it back up 3 degrees.
Posted : 21/10/2022 5:46 pm
The circumstances are that I want hot water... not that unusual?
Posted : 21/10/2022 5:52 pm
Step back. Look at the bigger picture.
Your boiler has to meet a wide set of circumstances. As part of the system it's not designed to be super efficient for the hour or so it has to heat hot water.... But the 6-8 hours average Joe uses their heating.
Posted : 21/10/2022 5:56 pm
I opened my windows to let the warm air in. Then closed them.
Re fixed the blades to the ceiling fan.
Lit the fire. Room temp up from 13°c to 17.5°c.
Gas central heating remains off until outdoor low single figures occur. I hope.
Posted : 21/10/2022 6:54 pm
Lit the fire.
LOL
T-shirt all day, put the aircon on driving home. Looking at the forecast it'll be at least another couple of weeks before I need to turn the heating on.
Posted : 21/10/2022 8:01 pm
Lit the fire here too because it's cold outside.
Posted : 21/10/2022 8:32 pm
 irc
That's it on now. Last two days after opening the windows for a couple of hours in the morning I've just set the thermostat to 17 or 17.5C and left it on all day until turning it off at night.
That said it's hardly firing.
Other economies are being made though. In the thriftifarian tradition I bought Aldi own brand whisky this week.
Posted : 21/10/2022 9:21 pm
My wife announced yesterday that we weren't putting the central heating on until November. Very laudable.
That's my wife with the electric blanket on her side of the bed, electric knee blanket and heater in the office, and constantly wanting the log burner lit of an evening 🙂
Posted : 21/10/2022 10:01 pm
trail_rat
Lit the fire here too because it’s cold outside.
Conversely ,we lit the fire because it was cold inside , LOL.
My wife stubbornly refuses to put on the CH , all thermostats are set at their lowest point , and like the ARP warden in DAD's ARMY she keeps shouting turn that light out FFS !!!!
AND , so long as it's not actually raining clothes are still being pegged out on the line to 'dry'.
Although I noticed some were back in, on the landing on the old clothes horse the other day.
Posted : 21/10/2022 10:43 pm
It's not cold, so don't need the heating on. Sat here in joggy bottoms and hoodie, just sitting around. Going to brave the not-coldness and remove the hoodie.
Posted : 21/10/2022 10:58 pm
 pk13
It's still not the wife's birthday so it's still off. We have been keeping the humidity down thou and that helps.
Not long now folks.
We went pumpkin picking at the local farm on Tuesday 3pm and scorching hot in the field.
Posted : 21/10/2022 11:23 pm
My usual thinking is you mostly go into October with it still warm and finish with it being bloody Baltic but it's barely gone lower than 10c in South Wales apart from a touch of frost randomly a few weeks back, it's set to be 15/16c all next week daytime
I've hardly noticed the boilers not connected to the rads yet, but that's said in a 'the worst is yet to come' rather than 'i'm nails me' kinda way.
Plumbers due Thurs mind to pop the rads on though so there's a get out for Nov/Dec
Anything north of 10c always makes me feel a bit warmer as its my threshold for not wearing gloves on the commute.
Posted : 21/10/2022 11:59 pm
I'll be connecting and bleeding the system tomorrow.
Still won't be on though....
Posted : 22/10/2022 12:57 am
TLDR I see a few attempts to improve condensing by reducing flow temp. Wondered if anyone fiddled with pump speed as well.
New boilers have this option I think and separate pumps are usually 3 speed.
Posted : 22/10/2022 9:57 am
I'd like to reduce the pump speed but I'm not sure I can on mine. I haven't seen anything on it that suggests I could.
Posted : 22/10/2022 10:02 am
Well it's warmed up today.
Ironic really that I'm sweating my tits off in the attic trying to improve both insulation and airtightness of the upstairs
Posted : 22/10/2022 3:45 pm
Too warm for a fire today 👍.
Living room has stabilised at 15°c.
Posted : 22/10/2022 4:33 pm
Pumps.
You might save a bit of electricity (50-100w ish) slowing the system circulation, but generally the rule of thumb is the lower the system temp, the quicker you need circulation to prevent temperature drop across the circuit as it radiates into the rooms.
Posted : 22/10/2022 4:47 pm
Lit the burner this am for my youngest as we’re heading out soon. That was a mistake the sun came out soon after and its melting in here.
Posted : 22/10/2022 4:49 pm
Pumps.
All modern CH pumps are energy saving already - they sense the number of one TRVs and back off if there aren't many demanding HW. Building regs changed maybe 15 years ago to mandate them in domestic CH.
Posted : 22/10/2022 4:52 pm
Had a couple of days off prior to a short break. Planned to bleed the rads but forgot. Hoping that does bite me in a few days time.
Posted : 22/10/2022 7:07 pm
Eaves kneesalls and dormer on front of house are all first fix superquilted tomorrow I'll fit the battens to hold it there perminantly. And seal the edges.
If Screwfix ever get round to having the other roll and the roll of double bubble I'll get the back of the house done. . Forgot how big the eaves are at the front of the house. Probably make a door into them and floor them for storage since I'm in there.
Posted : 22/10/2022 7:15 pm
All modern CH pumps are energy saving already – they sense the number of one TRVs and back off if there aren’t many demanding HW. Building regs changed maybe 15 years ago to mandate them in domestic CH.
I don't think ours is. How can I tell?
I found the balancing valve for the hot water circuit. It controls the speed through the water heater but this only serves to make the outflow temperature hotter. I don't think the temperature control knob on the boiler is working properly.
Posted : 22/10/2022 8:39 pm
Last staple.of the night...... Right through the ring main for the upstairs circuits.
Lucky I had the wagos handy in the upstairs cupboard so we were back in action in a few minutes.
Just come out the eaves attic where it's still about a million degrees to find......the fires on.
Nae amused.
Posted : 22/10/2022 9:00 pm
Lovely and warm today, windows open. Got a bead on wearing jeans and t-shirt whilst taking the dog for a walk this morning. Makes a nice break from the rain. Although that looks to be returning tomorrow 🙁
Posted : 22/10/2022 10:39 pm
As always, i think it’ll be the damp that gets me to heat the house, not the cold. Barely opening the windows and drying inside along with showers, cooking and continual rain eventually needs something. The doors will start to rub within the week, which may be the trigger.
Posted : 22/10/2022 11:24 pm
+1 Daffy.
House is fairly comfortable at the moment but we did two loads of laundry at the weekend, one on Saturday night and one last night. The Saturday load isn't quite dry and last night's load needs to be hung out. It was quite a big load, to be fair. We still have the option of tumble drying it on cheap overnight power, but that's more of a faff because it requires doing different fabrics in different loads.
Posted : 24/10/2022 9:41 am
Aaaannnd, still in shorts and no heating (obv) in Cambs... 🙃
Posted : 24/10/2022 9:49 am
Just saw this:
In my house the rads are all really small, so the temperature difference across each one is only about 6C except the hallway one which is big.
Posted : 24/10/2022 10:22 am
Aaaannnd, still in shorts and no heating (obv) in Cambs… 🙃
Yes, noticed the new grass seed I planted a couple of weeks back is growing nicely....
The summer heat pretty much destroyed more than 50% of it - so a lot of reseeding required.
I don’t think ours is. How can I tell?
What is the make and model?
Posted : 24/10/2022 10:28 am
Still no heating on down here in Bromley - shorts on all day yesterday!
WAs hoping we'd get to November before putting the heating on - weather forecast for this week suggests this'll happen.
Posted : 24/10/2022 10:40 am
Finally caved yesterday and popped the CH on - not because of the cold but because I was decorating and the sodding paint wouldn't dry so I could give it a second coat.
As above with Daffy, it'll be the damp before the temperature. Already starting to feel it a bit, and the bathroom door is sticking. worked out 3 hours of heating is the same as a dehumidifier for 45 minutes...
Probably completely against the current trend, but bought a tumble drier for the garage, purely to avoid wet washing in the house adding to the dampness. costs about 50p per load for bedding. better than having them on radiators/horse for 2 days.
Posted : 24/10/2022 10:43 am
No heating on up here in South Shields................yet.
Though I have taken to wearing jeans and long sleeved tops now. Might put it on for my wife's birthday on the 30th, but that's all she'll be getting 😁
Posted : 24/10/2022 10:47 am
in a 100% non scientific experiment - the bits of my eaves I've managed to get covered in superquilt while not completely air tight - is significantly more airtight than the loosely propped up glassfibre that was there before ( and the glassfibres still there between the joists
the IR thermometer says - walls i have got the spaceblanket on are the same temperature as the internal walls.
The walls i dont have super quilt in - on the same aspect were 2 degrees lower than the internal wall temperature.
On friday all the external walls were lower temeperature than the internal walls
that'll work for me to show its at least doing something. - lets see how it goes when the Delta T gets larger.
Posted : 24/10/2022 10:50 am
Humidity in our house has been rising steadily over the last couple of weeks. Temps are acceptable, but the air is feeling colder. Washing is begining to be difficult to dry and as others have said, a couple of doors has started rubbing.
Im in two minds as to buy a dehumdifier or just put the heating on.
Get one. Been raining all WE here, so we just dried the washing in the spare room with the dehumidifier - cheaper than using a dedicated drier and also dries the house out a bit....
Posted : 24/10/2022 10:58 am
Range Tribune. Appears to be dumb as a post.
in a 100% non scientific experiment – the bits of my eaves I’ve managed to get covered in superquilt while not completely air tight – is significantly more airtight than the loosely propped up glassfibre that was there before ( and the glassfibres still there between the joists
Where exactly have you put this?
I've bunged the clothes in the dryer as a one-off. It's going to cost a couple of quid.
Posted : 24/10/2022 11:06 am
on the back of the part termed knee wall in this diagram in both sides of the dormer cheeks - as well as around the front apron of the dormer while maintaining the "air flow" from the soffits up and over the roof space into the attic and down the other side.
Historically as you noted from your cavity thread - we would have the air flow coming through the glasswool and you could feel it around the sockets etc - not lots but it was there - and the wall was noticably cooler in winter than internal walls. the plan is to get them all done- and then look at getting something into the sloped areas that i can incorporate into that envelope while retaining the 50mm airflow required - its looklikg like recycled plastic fibre with slightly oversized double bubble holding it slightly compresed leaving clear air flow - taped at both ends.
the rockwool solid batt experiment didnt work but thats going to be repurposed into the roofspace above my dormer which appear to be empty
Posted : 24/10/2022 12:19 pm
13C day and 7C night, it went on.
19C is toasty, it's set to 18C most of the day which is fine. Having a low flow temp and a slow flow speed whilst being on for longer really makes the heating work better.
Posted : 04/11/2022 12:55 pm
yeah we caved in on the 2nd Nov...
Posted : 04/11/2022 12:57 pm
Ours has been "on" all summer - combi boiler and thermostat left at 14. So it wasn't actually heating.
This morning was the second time it actually fired up.
Posted : 04/11/2022 12:59 pm
3c here last night. I nearly was forced to close the bedroom window.
Posted : 04/11/2022 1:00 pm
After a record breaking October 3.5°C above the average we're back to seasonal weather in these parts. 12°C outside and 19°C inside. Madame hasn't moaned yet but it won't be long before she tells me its under 18 and time to light up. I think it's the first year we've got to bonfire night without any heating.
Even the solar thermal kept producing shower-hot water until a week ago thanks to sunny days and warmer than usual mains water.
Posted : 04/11/2022 1:02 pm
1°C overnight in my part of Cheshire (ice on car windows)
Still got my bedroom window open, no thoughts of putting heating on yet.
Posted : 04/11/2022 1:19 pm
Still not on here in the midlands, though it's getting close.
We have moved to a thicker duvet though.
Posted : 04/11/2022 1:21 pm
Yeah we succumbed on Wednesday, thermostat set at 18 & just a bit to chilly to WFH when it dropped below that.
Posted : 04/11/2022 1:33 pm
Mines hasn't come onfrom thermostat since I improved the airtightness of upstairs *
+1 degree - tropical
We had -5 when I got to the car this morning.
Hard frost on everything
Posted : 04/11/2022 1:36 pm
Finally set mine to come on this morning to get a couple of rooms to 20c
Posted : 04/11/2022 1:40 pm
bit chilly this morning in norn iron so heating went on for an hour.
sun's out now so more toasty 👍
Posted : 04/11/2022 1:41 pm
yeah we caved in on the 2nd Nov…
Same here, it's the latest we've ever managed. Set to 18 with strict instructions not to touch it. Bit of a ruckus last night when she tried to justify using the tumble dryer to dry my lad's work trousers that he doesn't need until this afternoon. Heating or tumble dryer, pick one, was my response... 🤣
Posted : 04/11/2022 1:46 pm
2nd November here too.
Bathroom towels weren't drying between uses and started smelling, the house was permanently festooned with backed up washing that wasn't drying before the rest came out of the machine, humidity at 90% indoors at 17.5 degrees.
We were actually pretty ok from the warmth perspective, but the whole admin of the house and living conditions were deteriorating.
Posted : 04/11/2022 2:06 pm
Yup, drying clothes has forced us to use the heating now also. And it's been flipping freezing!
Posted : 04/11/2022 2:25 pm
Bathroom towels weren’t drying between uses and started smelling, the house was permanently festooned with backed up washing that wasn’t drying before the rest came out of the machine, humidity at 90% indoors at 17.5 degrees.
Dehumidifier...
Posted : 04/11/2022 2:28 pm
Still off here with the exception of 2 short early evening top ups earlier this week. Towels not been drying properly for a little while. When we put solar panels in I am definitely going to add electric elements to the towel radiators for the in between periods. Tumble dryer is in use now as been too wet to hang outside.
Posted : 04/11/2022 2:30 pm
Dehumidifier
False economy. Would need more than one at £130 plus each, then running costs at a unit cost for electricity still more than triple that of gas even now.
May as well just use the gas get all the same benefits and be a bit warmer too.
We're fortunate that we have a fairly well insulated house and big radiators so my experiment with 47 degrees flow temperatures is going well so far boiler is actually barely firing presently.
Posted : 04/11/2022 2:34 pm
My boiler has been trying to turn on for weeks as the house has been consistently below 15 deg in the morning and evenings.
I caved today and let it do its job - good Lord 17deg is nice after weeks of soakings while commuting.
Posted : 04/11/2022 2:40 pm
Page 8 / 27
