I put mine on a timer so my bed is fully heat soaked and I fall asleep really quickly.
Then there's no chance of leaving it on and waking up at midnight and feeling like you've in a slow cooker
Not well. Drained the system yesterday, replaced a couple of faulty TRVs, refilled with inhibitor.
Forgot to reset from default to miser-mode and blew October's DD payment (maybe 🙂 )
12°c in the kitchen this morning.
No negative Agile power either! So I'll have to make do with a brew, hat and gilet!
Bedroom is around 17°c . Electric blanket connected to a smart plug will return later in the year.
Ours has been on the evening for a few evenings now - outside overnight temp low was 5°c last night and 6°c (and windy) the night before. Currently 9°c outside apparently and between 13.5°c and 15.0°c across all rooms, looking at my Honeywell app - smart TRVs in all rooms. Sedentary WFHer most of the time and persevering without heating this morning as about to head out onsite.
Not willing to freeze my bollocks off to save a few quid.
13°C inside the van this morning. 5°C outside.
Have been in the Friulian Alps the last three months. Most days over 32°C and nice cool nights at ~17°C rather than 25+°C down on the plain.
Now parked up near Rosengarten in the Dolomites at 1800m and it's pissing it down with the occasionally sleety shower..... And we've got to go north to Germany where it's also pissing it down and the highest temp next week is 14°C....
Heating has cut in the last couple of mornings at 17°. Have to say it just takes the chill off the bathroom and I like a "not feeling cold" towel when I get out the shower. We turn it off when we're all up and dressed.
We're lucky, we can afford to make that choice. Must be miserable for those that can't.
16-18C in the house, and around 12C outside in Bristol. Certainly felt the change in evenings and mornings, but no chance heating will go on - from tomorrow temps are starting their rise to 22C next week.
No, still in the "wearing more clothes" phase.
Will probably pop it on when I have company though.
Haven't put the heating on yet but it's bloody cold this morning.
Northerly wind pulling cold air down.
Wish i had put my long trousers on this morning.
my garden data logger suggests we got down to 4 degrees last night + wind.
The kids bedroom declined to the point the heating kicked in at the set point.
i cant get my chimney any better insulated short of filling it top to bottom - which I'm reluctant to do - its Capped at the top with a breather - its vented at the bottom - with a chimney sheep just inside the throat.
The rest of the house stayed at the original set point - with the same insulation levels but lacking a chimney.
Hey,
Nothing on in Sunny North Somerset, and we are high up overlooking the Seven Estuary. I haven't even used the log burner yet...
JeZ
Got rid of the oil fueled central heating and replaced with ASHP a few months ago so just getting the hang of things. Slight complication is the previous owners installed electric UFH in the kitchen so currently playing around with the thermostats to limit this turning on first thing. Single figures outside overnight, inside is high teens early morning, so not cold yet but trying to optimise the system before it does.
Just put the heating on, couldnt take it any longer as legs freezing(very poor circulation)
Yes having the heating on is pricey these days, but you set yourself up for an increase of illness if you spend too long in the cold.
Kids complained bitterly this morning so as WFH fired it up for the annual radiator bleed to be presented with a dead zone valve. Typical
Last two nights have been below 3°C heating kicked in when thermostat shows 16.5. keeps the damp feeling at bay.
Been helping the eldest child change the clutch on his car today. Now I've come in I've realised how cold I got. Thermostat in the house says 18.5 Celsius, which considering we're now all in is a bit on the low side.
Still not putting the heating on as I'm way too tight. Still wearing shorts mind :->
Had my heating on now for 4 weeks.Feeling the cold due to illness.
First log-burner light this evening…
Not yet but had the wood burner on the past couple of days. 18°c upstairs, 23°c in the living room.
On for one morning this week (Wednesday?):
Was 1C outside so had the heating on for an hour to bring the house up to 16C. Then off.
I've crumbled... thermostat currently set to 18, and knocked down to 16 at night.
I’ve probably mentioned it earlier in thread but my stove/log/coal burner has only been off on two occasions this year, I lit it at 2pm today.
Ground source here, so it's basically on all the time.Lovely warm floors in the morning 🙂 Still in Spring/Summer mode tho so the "winter" shirt has been extracted from the wardrobe. In the shed where I work in the day, had to run the electric oil rad in the mornings a couple of times, but even as 2KW max, it get the room up to temp pretty quick (shed is well insulated).
First time for dog walking, needed the XTR beanie this morning. 6 degrees and very limited natural thatch required hat deployment 🙂
We've not fired up the wood burner yet, but that's mostly because the sweep is coming next week and we made pretty extensive use of it last year. So I'd rather de-soot the chimney before first lighting.
How long would 900 litres last mate?
Here's a thing, My thermostat is currently set to 18 degrees, and is reading 18 degrees room temp, so my boiler is currently 'dormant' as expected...
At my desk the other side of the rooom I have a temp/hydro meter, which is reading 19.6 degrees which is kind of expected as it's near my computer, screen, and me, so it's probably as expected.
However I still feel a bit chilly...in summer when my room is 19 it almost feels too warm? what is going on here? is it my relative humididty which is a little on the high side at 61%, currently, but that's not insanley too humid, just a little on the high side?
However I still feel a bit chilly…in summer when my room is 19 it almost feels too warm? what is going on here? is it my relative humididty which is a little on the high side at 61%, currently, but that’s not insanley too humid, just a little on the high side?
Your body gets used to warmer/colder temperatures. I'm in central Spain, so the thermometer's skewed to the right, but last week I've started to feel chilly when it drops below 25C, whereas in winter that would be roasting.
Electric heating on later this evening for an hour whilst the price is less than 2p/kWh. I could run it for a few more hours at a sub 3p/kWh but I'll save my pennies for later on in the year.
Wood burner has also been lit this evening.
I nearly (not really) died this weekend camping in a field both nights. By eck it was chilly!!
Our heating has been on for a few days and I thought there was an issue - very little heat seemed to be doing the rounds.
Conformed today when what sounded like the circulation pump jamming...cue dead boiler.
First year with a full 20kw of panels on the roof, Just coming out of winter here and we’ve only got through about 1 tonne of firewood. The reverse cycle air con has been set to 24 degrees and has kept the chill off the house nicely. Looks like payback on the additional solar and battery will be quicker than anticipated.
it’s still a very okay 16deg and the summer duvet stays on all year around.
We used to keep our daily temp at this, both my wife and I were working from home at the time. She used a small electrical blanket if she felt cold sitting still for so long. I was flamed on here and somebody said they would be divorced if they let theres lower than 23....
We have an ASHP now and this will be our first winter so will be interesting to see how we get on. I have the thermostat set to 18 now (which i think is more accurate than our previous 50+ year old gas boiler) So far it feels fine.
Camping for two nights this coming weekend - it's going to be cold.
for us (detached house in norn iron) 900 litres probably lasts about 3 months over winter, it does our heating and hot water, we WFH a lot, so are around in the daytime in the house, I try to just stick on another fleece or wear a hat rather than heating the house more than we have to!
People been coming round viewing the house (Fri, sat & today) so notched the stat up to 20C to keep them from thinking they were looking at buying an oversized refrigerator.
Electric blanket and winter duvet will be returning this week
Annual E-blanket and duvet change has occurred.
Almost held off to Oct 1 but had to relent this evening. Ah well. Needs must. We’ll still be sitting under rugs and wearing jumpers watching the box and its not timed ON upstairs yet. Every year that passes, a cold house feels colder.
E-blanket
Are they as hated as eBikes?
Probably, but not in this household!
For every 37.5°c I put in, the E-blanket adds 30/60/90W of additional power depending on which setting I select.
Still not had it on.
South Central Leamington Spa
The central heating was on the last three days but not today.
Still barefoot around the house and only shutting the windows at dusk in south Pembs.
It was 17° today and yesterday.
Had -3 as a low this week. Had the stove on
Back up to 18 today - not had the stove on
