New Tyres on a FWD ...
[Closed] New Tyres on a FWD car?
New boots required as the fronts are worn.
Best advice is to put new ones on the rear if there's going to be a difference in grip level.  Rears are currently hovering around 5mm or just over.  So, in this case, it's probably not going to make much difference right?
If I put the new ones on the front , by the time they are all worn out, I can change all 4 for a newer tyre model.
Posted : 23/11/2018 10:56 am
Swap them around if you're that worried about it. Depending on your car, if it goes through front tyres quickly, they'll soon all be equal anyway. I wouldn't be losing any sleep over it with that amount on the rears.
Posted : 23/11/2018 11:06 am
We have a Mazda 3 that likes to eat front tyres (lucky to get 12k out of a set even though the car is only 150bhp and I drive like Miss Daisy). I always swap front to back (ie, new on front then, when they are about 50% worn, put them on the back and a new set on the front). Otherwise, as we do low mileage, the rear ones start to crack long before they are worn.
I have never, not once, had any issues with any perceived lack of grip.
Posted : 23/11/2018 11:20 am
I'd rather have the grippiest / freshest tyres on the front of a FWD car. The rear do hardly any of the braking steering work, so will last for ages.
Oddly ours needed rears (I replaced the fronts last year) this year, so I got them replaced and swapped the wheels with the new tyres to the front and moved the 1 yo tyres to the rear. Nice to finally get rid of the annoying slow puncture in one of the rears.
Posted : 23/11/2018 11:32 am
What they said, don't see why you'd want nice fresh tyres on the rear, you'll only end up with really worn front ones fairly quickly, and an even worse imbalance than you have now.
Posted : 23/11/2018 11:35 am
Every single tyre manufacturer and the AA, RAC etc all give the same advice. Best tyres on the rear.  That's good enough for me.
Posted : 23/11/2018 11:46 am
@retro83 - yep, that's the advice I usually listen to.
I guess, it's the fact that the rears are currently still in pretty decent shape, so there isn't really a discernible difference in choosing "best" in this case.
Posted : 23/11/2018 11:54 am
Odd innit.
Different views n’all.
I put new tyres on the front of the roadster (4wd) last time and this time changed all 4 at the same time.
So by my working out, if the fronts wear first then change them by the time the rears are worn too change the lot.
Posted : 23/11/2018 11:56 am
I'd think best tyres on the front on a FWD car. More grip for the driving and braking wheels.
Posted : 23/11/2018 12:02 pm
if you just keep changing the fronts then it can get to the stage where the rears are perishing due to age. You will also have a much longer time with low tread depth on the rear as the wear period is stretched out.
Putting 2 new on the rear now and swapping does not stop you changing brand, it just means your OCD will suffer for a while until you can replace the next 2 and you risk not being able to get the same tyre...
On my FWD cars I have always rotated the tyres regularly to even out wear, I have to do this on the 4wd but on the rwd this is not an option as they are staggered (different tyre widths front and back). I would rather take the hit on 4 tyres in 1 go, especially as you can normally get a better discount.
5mm sounds like lots but it's already almost 50% worn down to the limit (i would normally change at 2.5 to 2mm not  wait to 1.6)
 sbob
Every single tyre manufacturer and the AA, RAC etc all give the same advice. Best tyres on the rear. That’s good enough for me.
Oversteer vs understeer.
Understeer is seen as safer.
Posted : 23/11/2018 12:04 pm
The advice I get is to have 4 tyres the same all round
Don't swap partially worn tyres to the rear on FWD - from safety perspective your rear grip should ideally be as good/ better than front (perhaps losing front grip is easier to deal with on FWD).
Just what I've been told - don't know if its in any way specific to the car I drive.
Posted : 23/11/2018 12:08 pm
PS the "handling" reasons for new on the rear is to avoid oversteer or the back losing grip during wet braking which the regular motorist is less likely to be able to catch and a lot more dangerous than good old understeer. While tread depth is normally put forward as the main reason it can also be new tyre developments and in choosing the best performing current tyre you can make it worse by keeping the old "rubbish" on the back. It is not uncommon to see fwd cars with rear tyres over 10 years old as they wont die but are all hard and perished and an older design.
That said it is easy to over think these things. I always put the best tyres I can on my cars and will take"perfectly good" budgets off a car I buy to put something decent on which might be OTT given how most other motorists view their tyres.
Posted : 23/11/2018 12:09 pm
Best tyres on the rear is safest - if one end loses grip due to being the worst tyres you want it to keep you pointing the right way along the road.
That said, with 5mm on the rears I wouldn't worry about putting new tyres on the front on anybody's car, as long as they're the same tyre. Be aware that it could mean that the rears could slip first in certain conditions where you really wouldn't want them to though (deep standing water, snow).
Posted : 23/11/2018 12:15 pm
Agree, best on the rear as losing control of the front is the lesser of two evils.
But since most cars have ESP now perhaps it isn't as important as it once was.
Posted : 23/11/2018 12:20 pm
I run cross-ply remoulds - different make on each corner! 🙂
Posted : 23/11/2018 12:23 pm
I’d think best tyres on the front on a FWD car. More grip for the driving and braking wheels.
I'd always thought the same but the reason they should go on the back is the last thing you want is the front stopped with the back still moving.
Posted : 23/11/2018 12:25 pm
Indeed. Lift off oversteer = "fun"
As others have said the best/most grip/newer tyres should always be on the rear of a fwd car, you can argue against this if you like but you are wrong.
Posted : 23/11/2018 12:35 pm
Don’t swap partially worn tyres to the rear on FWD – from safety perspective your rear grip should ideally be as good/ better than front (perhaps losing front grip is easier to deal with on FWD).
I guess I can see the reasoning for this but in 34 years of driving I have never really had an issue where I have lost control of a car due to conditions (I have when I was driving in excess of the conditions) so unless you are driving like a knob I don't see a significant risk in doing what I have done for the last few years (reason stated above).
Posted : 23/11/2018 12:49 pm
But since most cars have ESP now perhaps it isn’t as important as it once was
Indeed, very much less of an issue these days. But tyre age is still one to be wary of and there was talk of introducing it as an MOT point as well as the condition.
Posted : 23/11/2018 1:26 pm
Lots of "sample size of one" going on here.
That aside.
If the rears wear down at 1/4 the rate of the fronts, and you don't rotate, even on a fresh set of tyres your fronts are only going to be better than the rears for about half the time anyway.
If you always rotate and put the new ones on the back, your fronts will start off pretty close to full tread depth anyway.
So why not take the advice. I've never been charged when I've asked a garage to rotate the tyres when they're fitting new ones, it's a minute job for them when the car is up on the lift.
" run cross-ply remoulds – different make on each corner! "
Drum brakes and leaf springs all round as well? WW2 Jeep replica?
Posted : 23/11/2018 1:28 pm
Best tyres on the front for me; they are the ones that hit that standing water first so they need deep grooves.
Posted : 23/11/2018 2:06 pm
Regardless of which wheels are driven and what's happening when you are braking - all the wheels are doing the turning. The fronts get the majority of the wear on an FWD but it doesn't mean they are providing all the grip when it matters. The reason the 'official' advice favours the better tyres on the rear is to do with the dynamics of all the tyres in the kind of turn and kind of speeds that can turn into an accidents. Favouring grip on the front makes those accidents more likely and bigger.
Based on actual testing rather than 'I'd think"
But if you're not planning on having an accident it'll be fine 🙂
Posted : 23/11/2018 2:28 pm
 DM52
In the 10 years I had an Impreza I didn't rotate the tyres once.  Maybe it is not as important in the southerly climes of this country but I never had any issue.
I think there maybe an element  of overthinking this conundrum, when an axle needs fresh boots they get them.
Posted : 23/11/2018 2:36 pm
Best tyres on the rear is s that if you overcook a corner it will understeer not oversteer as understeer tends to lead to less nasty accidents.  But you will reach the limits earlier this way especially under braking.
With 5mm of tread left on the part worn tyres this won't really matter - that advice is more for when the tyres are almost worn out.  In the OPs situation I would definitely put the worn tyres on the rear.
Posted : 23/11/2018 2:42 pm
tjagain
Member
With 5mm of tread left on the part worn tyres this won’t really matter – that advice is more for when the tyres are almost worn out. In the OPs situation I would definitely put the worn tyres on the rear.
It's not just that, aquaplaning will usually occur on the most worn tyres first because shallower grooves cannot clear as much water.
Posted : 23/11/2018 3:38 pm
Less weight over the rear axle of a car will also contribute to loss of traction/more chance of aquaplaning on wet/greasy roads so best tyres should be on rear of fwd car, lift off oversteer is great fun to play around with/familiarise yourself with in a hot hatch when on a track but if it happens on a public road then you are pretty much ****ed as it happens in a split second.
Posted : 23/11/2018 4:02 pm
Always newest tyres on the front for me.  They do the work on a FWD car.
Posted : 23/11/2018 4:26 pm
Hedge your bets and plough your own furrow. Put a new one on the back and a new one on the opposite corner on the front Everyone’s a winner.
Posted : 23/11/2018 4:35 pm
It is quite perplexing how many folks think they are right on this despite all the manufacturers and experts advice.
So could somebody post some <u>real </u>evidence for the "wrong" answer please ?
Posted : 23/11/2018 4:40 pm
Best tyres on the rear is safest – if one end loses grip due to being the worst tyres you want it to keep you pointing the right way along the road.
Following on from this, it’s not about traction front and rear when pulling away furiously. New tyres go on the rear because when things go tits up or should that be sideways, it’s easier to control a front wheel skid than rear wheel.
Same with a blow out, on the motorway/ fast road most people will control a front blow out and pull over safely, most people won’t control a rear blow out, and end up in the barrier/ hedge
Posted : 23/11/2018 4:57 pm
Always newest/best on front for me too (and decent on both ends). I totally understand the opposite position and especially why manufacturers and shops will stick to that advice since a rear end slide is more likely to be catastrophic. IF it happens.
But what it's always meant for me on my cars and for my driving is, you're trading safety in a rear wheel slide which essentially doesn't happen, and losing safety in a front wheel slide/slide avoidance which actually is relatively likely.
That comes from a lot of things- shitness of the rear brakes in my cars definitely plays a part, and the general fact that with loading and workload and that, most situations that would cause the rear to slide can also cause the front to slide, and even with the better tyres, the front will go first so the situations where the rear can slide without the front sliding first are extremely rare (ice and snow, fundamentally, where your normal tyres suck regardless of which way round they are)
Ooooor, put it another way; in my 2 fwd cars I was always likely to go through the hedge forward. Improving rear wheel traction reduces the chance of going through the hedge backwards but improving front wheel transaction reduces the chance of going through the hedge full stop.
Posted : 23/11/2018 5:15 pm
the-muffin-man wrote
I run cross-ply remoulds – different make on each corner! 🙂
radials near side and crossply off side here
Posted : 23/11/2018 5:26 pm
But since most cars have ESP now perhaps it isn’t as important as it once was.
This is true, but if you were to do something totally irresponsible like going round a roundabout in a manner so as to deliberately provoke oversteer and not correct it until the ESP kicked in, you'd find that the car will be sliding a bit, which it has to or the ESP would be limiting your cornering ability, but that could still induce a bit of panic in more sensible drivers faced with an emergency situation.
So I guess what I'm saying is don't rely on the ESP, it might not save you as much as you would perhaps think.
Posted : 23/11/2018 5:33 pm
I did actually run a car with cross plys on the rear and radials on the front - but I was young and it was a relatively powerful rear wheel drive car and a long time ago , and i thought it was logical  - in the wet it was very exiting .
(Actually illegal and for reasons not entirely (pun  intended) similar to this thread)
Posted : 23/11/2018 5:38 pm
But what it’s always meant for me on my cars and for my driving is, you’re trading safety in a rear wheel slide which essentially doesn’t happen, and losing safety in a front wheel slide/slide avoidance which actually is relatively likely.
Thats a very good point, maybe the manufacturers are covering their rears, ahem, legally rather than thinking about  what is most likely.
but since most cars have esp now...
wouldnt esp help more controlling a front skid/ slide rather than the sort of rear end sideways that would cause a massive problem?
It says in my car’s hand book something about esp not being able to change the laws of physics!
Posted : 23/11/2018 5:53 pm
This.
All modern fwd cars (and nearly all others) are designed to understeer fairly significantly when traction is exceeded. Making this worse is a poor idea in my opinion, but it does make such situations easier to deal with for inexperienced drivers.
Posted : 23/11/2018 5:56 pm
I thought putting radial tyres on the front of a car which had cross ply tyres all round would be better/safer
because I was clever and there  was no internet then.
So - can somebody do the evidence thing , online video of the difference would be ideal.
Posted : 23/11/2018 6:04 pm
I was advised a few year ago by a MIRA observer (was at a car show) that if you stick to quality branded tyres then you should be fine sticking new tyres on the front as long as the rears were less than half worn which is around 5mm (8mm-1.6mm = 6.4mm of legal tread usage. 1.6mm+3.2mm = 4.8mm).  Any higher a difference front-rear and the back can overcome the car's natural understeer too easily for any ESP to save you.  Makes sense to me so I've stuck to it.  I change my tyres at 3mm anyway so more often than not it's a full set off boots for every 2nd pair on the front.  That may make me drunk on the manfacturer's Koolaid to make me buy more tyres but seeing as they are the only point of contact I have with the road I'll happily spend a bit more on decent tyres and change them before they are close to the legal limit.  If it saves me from having even one small accident it's worth it.
Posted : 23/11/2018 6:08 pm
You may also wish to bear in mind that grip in the wet begins to drop off very significantly once tread depth drops below 3mm.  the legal limit may be 1.6mm in the UK, but the performance is dropping well above that.
wear indicators are at 2mm,  I understand that is the legal limit elsewhere in Europe.
Also bear in mind, what ever you do is never the safest in every instance, merely some.  I suspect the instances that lead to the advice from the AA etc. is not drivers 'pushing on', its more likley a driver stamping on the brakes suddenly after being taken by surprise. Good tyres up front and the back is pretty sure to come round I guess.  Good tyres to the rear, and run the risk of a longer stopping distance but ability to steer around an obstacle.
Posted : 23/11/2018 8:33 pm
No not really, most FWD cars will oversteer readily on a trailing throttle.  E.g. wet weather, you go into a corner, realise you're going too fast, and lift off the accelerator/dab the brakes = spin. Having the best tyres on the front exacerbates this.
Posted : 23/11/2018 8:36 pm
No, it's there to help keep the car in a straight line (if at all possible, of course!).  There are some great videos on youtube demonstrating this - it really is very impressive.
As others have pointed out, it can't undo the impossible - but it's there to help prevent the car from sliding and to maintain it's direction.
Posted : 23/11/2018 8:43 pm
New tyres always on the back for me. The fronts wear out, the recent rears get moved forward, new ones on the back. This avoids rear tyres getting 10 years old and cracking before they wear out.
I've seen enough crash clips of cars losing the back end under panic braking, generally they get cut in half by the nearest tree or smashed to bits by an oncoming truck.
The natural reaction to a car skidding and getting out of shape is to reduce throttle or brake. During oversteer, that action just makes things worse. During understeer, it's exactly the right thing to do as it transfers weight to the front.
If you need that extra 3mm on the front then you are placing too much faith in your tyres 🙂
Posted : 23/11/2018 9:52 pm
Thanks for all the comments peeps. Mostly you've backed up my theory and previous advice about putting the new tyres in the rear.
I always use quality tyres (conti sport contact 5 in this case) and pay attention to wear and pressures. In fact the "worn" fronts have just dipped below 3mm and in lieu of not fitting winter tyres (I know...a different discussion entirely) I'm replacing them at this point.
I've done some training in how to handle a car when it's sliding but I'm no drifting / driving god, and let's face it, on the public highway its the unexpected stuff that could catch you out anyway.
With all this in mind, I'm definitely putting the new tyres on the rear with the 5mm part worn tyres moved onto the front.
Posted : 23/11/2018 11:12 pm
I've come around to the idea of new tyres on the back, imagine if youre braking in the wet then all the weight transfers to the front. Aquaplaning is a function of pressure (i.e. weight) so makes more sense to have tyres that resist it most on the wheels that would be prone to it (rear).
Mathematics fail.
If a tyre wears out twice as fast and is replaced twice as often it only spends half as much time 'worn out' per tyre, but twice as often.
Posted : 23/11/2018 11:46 pm
Some weird answers on here!
If you've ever raced a FWD car on track in the wet especially, you'll realise why rear tyres are so important. Passive rear steer (accentuated with low tread on rear tyres) will mean that the rear of the car will let go pretty quickly if you do something like lifting off the throttle abruptly mid corner. There's not much weight over the rear of a front wheel drive car, so there's not much pushing the tyres in to the ground.
Contrary to what you might think from TV shows and car magazines, catching the oversteer in the limited amount of space you have on a public road is pretty hard.
Worn tyres on the front will promote understeer, which is much easier for most people to deal with - easing off the power gently will usually bring the front back in line.
JP
Posted : 24/11/2018 12:00 am
E.g. wet weather, you go into a corner, realise you’re going too fast, and lift off the accelerator/dab the brakes = spin. Having the best tyres on the front exacerbates this.
Anyone stupid enough to dab their brakes in a corner should expect that to happen. Having the optimum tyre set up isn’t going to solve stupidity.
Posted : 24/11/2018 12:03 am
Mathematics fail.
If a tyre wears out twice as fast and is replaced twice as often it only spends half as much time ‘worn out’ per tyre, but twice as often.
What the 'ell are you on about?
If you keep old tyres on the rear, then assuming it is 4 fronts to 1 set of rears you get:
End of 1st fronts - Rear 1/4 worn
End of 2nd fronts - Rear 1/2 worn
End of 3rd fronts - Rear 3/4 worn
End of 4th fronts - rear fully worn
Your rears have then been below half tread for 2 lots of front tyres.
If you swap tyres then for 4 sets of fronts you get:
End of first fronts - Rear 1/4 worn
End of 2nd fronts - New rears slightly less then 1/4 worn (as rears with 1/4 wear moved to front)
End of 3rd fronts - New rears less than 1/4 worn (as rears with  less than 1/4 wear moved to front)
End of 4th fronts - New rears less than 1/4 worn (as rears with less than 1/4 wear moved to front)
You never drive with rears more than 1/4 worn
Net result is by just changing the fronts your rears are more worn (than when rotating) for the time it takes to wear out 3 sets of front tyres longer than when rotating as their wear period is longer and thus extended.
Posted : 24/11/2018 12:36 am
and to put it another way - at the start of each new pair of tyres being fitted:
No rotation:
New fronts : New rears
New fronts : 1/4 worn rears
New fronts : 1/2 worn rears
New fronts : 3/4 worn rears
New fronts : Fully worn our rears - shit, 4 new tyres time as my rears are knackered.
With rotation:
Slightly worn fronts : new rears
Slightly worn fronts (but less than above) : new rears
Slightly worn fronts (as above) : new rears
and so on...never need to fork our for 4 tyres and never have rears below 1/4 worn (ie over 3/4 tread left)
Posted : 24/11/2018 12:43 am
@johndoh
So you've never, even once, found yourself going a little too fast into a corner with an unexpected tightening radius and had to lift off? You must be a driving god.
JP
Posted : 24/11/2018 12:45 am
@jjw - read what I said. Yes I would lift off. Only an idiot would dab brakes mid-corner. And to be fair, only a driving idiot would brake mid-corner if they’d overlooked the entry speed, no need to be a god to know that much.
Posted : 24/11/2018 12:49 am
Pretty much everyone brakes mid corner at some point on a journey. I see it every day on the lanes on my way too and from work.
It was drummed into me when racing to brake before the corner but every day I see some eejit panic brake as they have gone in too fast (or they think they are too fast).
In fact its amazing how much unnecessary braking most drivers do. Driving at safe road speeds on public roads it should be possible to barely touch the brake pedal with proper planning and smooth driving and not bloody panic braking as soon as you see another car or a bend.
Posted : 24/11/2018 12:54 am
...esp...
No, it’s there to help keep the car in a straight line (if at all possible, of course!).  There are some great videos on youtube demonstrating this – it really is very impressive.
As others have pointed out, it can’t undo the impossible – but it’s there to help prevent the car from sliding and to maintain it’s direction.
thats what I mean, a front skid will have a more linear progression without the pendulum effect of the  rear end swinging around, therefore esp is more effective in controlling a front/ under steer kind of slide.
Once the rear end swings around it is surly beyond the ability of esp to correct it, granted the braking action of esp could stop this from happening in the first place, if the slide rear end movement is gradual. But isn’t that is when a rear wheel slide becomes dangerous?
Posted : 24/11/2018 12:55 am
Exactly - enter the corner at optimum speed so you can accelerate at the apex rather than be stamping on the brake in a panic somewhere in between nothing and something else.
The only time I have braked in a corner was when doing rally driving days with the fly off hand brake when I *wanted* the back end to hang out.
Posted : 24/11/2018 1:01 am
[i]read what I said. Yes I would lift off. Only an idiot would dab brakes mid-corner. And to be fair, only a driving idiot would brake mid-corner if they’d overlooked the entry speed, no need to be a god to know that much.
Exactly – enter the corner at optimum speed so you can accelerate at the apex rather than be stamping on the brake in a panic somewhere in between nothing and something else.
The only time I have braked in a corner was when doing rally driving days with the fly off hand brake when I *wanted* the back end to hang out.[/i]
Errr, what about real life?  We are not talking about a spirited early Sunday drive through some scenic B roads with nice big sight lines, an empty oncoming lane and practically no traffic.
On Monday morning at 06:30 am, in the dark, in the drizzle and chain ganging along my local bendy A road with high hedges, there is no apex unless you want to mount the kerb.  Entry speed is limited by the car in front.  Oncoming motorbikes, wobbly cyclists, a tractor ferrying human sh!t to the fields results in queues or unexpected slow downs.  Queues you may meet halfway around a bend, doing a sedate 35mph with a nice slippery manhole cover/deep puddle/split diesel just waiting to catch you out as you touch that brake pedal.
Posted : 24/11/2018 7:56 am
I hadn’t appreciated that the rear tyres were so important on FWD cars. It’s pretty stupid, then, that the garage advised us to only use winter tyres on the front...
(Notwithstanding the fact this was regarding a 4wd car - although to be fair they didn’t know that (but didn’t ask)).
Posted : 24/11/2018 8:57 am
The under steer vs oversteer thing is a valid point but I think irrelevant. Most accidents on the road are not caused by people getting into an over steering situation. You’d have to be driving very aggressively to get into that situation. Most people crash because they are not paying attention and leave braking too late so in that context i’d rather have the best possible braking performance.....especially in the wet, so newer tyre on the front for me too.
I think some people have an unrealistic view of the relative wear rates between front and rear tyres. You’re unlikely to en up in a situation where the rears are so old they’re degrading away.
Posted : 24/11/2018 9:04 am
After reading this thread I can only wonder why the tyre manufacturers and motoring organisations just plucked a random opinion out of their arses about where best to fit a new pair of tyres instead of thinking it through properly.
STW exceptionalism at its finest!
Posted : 24/11/2018 9:21 am
I think we're both saying the same thing - ESP kicks in to help prevent the rear from swinging out in the first place - it dabs all four brakes independently to help keep the car in the intended direction.  Watch the youtube in my link - it's quite old but good old Tiff demonstrates ABS, traction control and ESP.
Posted : 24/11/2018 10:20 am
Yes, so if it goes according to what the engineers have designed it should induce a bit of over or under steer to stop the skid angle becoming too great , therefore preventing a crash?
I’ll watch the vid when I’m off child duty and can concentrate.
Posted : 24/11/2018 10:40 am
In your scenario I would be driving to the conditions and wouldn’t be in the position that I would have to brake mid/corner. If it DID happen, and I was driving too quickly for the conditions, there would be an accident. Whether the cause, other than driver error, would be tyre rotation choice or any other reason (worn shocks, under/over inflated tyres, failed suspension bushes, over-loaded weight in the boot, alien invasion, mumps or whatever) is anyone’s guess.
Ohh, and there is always an apex - it wouldn’t exist anywhere other than the optimum position on the road.
Posted : 24/11/2018 10:52 am
Surely what makes a car safest and covering arse legally are both valid business decisions?
One just has a lower moral motivation, one keeps the customer coming back and the other stops their family suing you, both improve profits.
Personally I go with the tyre engineers advice to put new on the back. Incidentally, two large tyre companies have told me that winter tyres all year round are better than summer all year round.
Posted : 24/11/2018 11:02 am
That is incredibly bad advice and goes against every bit of advice given about fitting winter tyres. It is highly likely that the winter tyres on the front will let you get up to a speed the rear wheels wont cope at and send you spinning when you try to brake or lose speed round a turn. Only way to correct that is keep using the front wheels to pull the car straight, like a car with a waggling trailer.
IIRC the only remotely acceptable position to only fit 2 winter tyres, if you must, is the rear of a RWD car which sounds mad to most people as they think about steering but on the rear driven wheels it means you have traction grip for moving off and rear grip for stopping. Even that is only a "if you must do it" and obviously the best way is all 4 tyres.
Posted : 24/11/2018 11:53 am
Costco tyre fitters are not allowed to fit new tyres to the front, unless there is a valid reason such as different sizes. Possibly something to do with them being a US company and some law or previous legal case following an accident.
I have seen people argue that they want them on the front and they will flatly refuse to change the tyres at all.
Posted : 24/11/2018 11:56 am
I think you have misunderstood what I was saying. It was a tangential point, their advice was that if you have only one set of wheels then 4 winter all year round is better than 4 summer. That was back in 2011 when both Continental and Michelin did not have all season tyres in their UK range. Michelin advised this over the phone, I will see if I still have the email from Continental.
I agree with what you say and it amazes me that I have heard tyre fitters advising ‘just winters for the front’
Posted : 24/11/2018 12:06 pm
If you’ve ever raced a FWD car on track in the wet especially, you’ll realise why rear tyres are so important. Passive rear steer (accentuated with low tread on rear tyres) will mean that the rear of the car will let go pretty quickly if you do something like lifting off the throttle abruptly mid corner. There’s not much weight over the rear of a front wheel drive car, so there’s not much pushing the tyres in to the ground.
Worn tyres on the front will promote understeer, which is much easier for most people to deal with – easing off the power gently will usually bring the front back in line.
JP
Yes but PEOPLE ARE NOT RACING ON THE PUBLIC ROADS so therefore so what.
For braking in a straight line you want the best rubber not the front, especially in the wet, and that is how most accidents happen. People crashing into cars in front of them in a straight line or something unexpectedly coming out in front of them, and not racing around bends, overcooking it massively such that they snap into oversteer. Depends if you want to configure your tyres for the most likely scenario or the least likely scenario.
If you get into a situation where you're getting a FWD car into snap oversteer...1. you deserve to spin off into the hedge and learn a valuable lesson in life - roads are not race tracks and 2. the chances are better and slightly grippier tyres on the back would not have saved you because you were driving like a dick.
Also the expert advice on this is not clear cut in that it is not better to have the best tyres on the back in ALL circumstances. there're pro's and cons to each option in different situations so there is not one rule to rule them all. According to Michelin the advantages to better tyres on the front are better grip and braking in wet and dry, and the advantage of having the better tyres on the rear is better braking on a bend on wet roads. So for me the better option for most situations out on the road are better tyres on the front and when entering a bend when its wet I'll just shave off a bit more speed than usual when approaching the bend.
Posted : 24/11/2018 12:55 pm
bsims did you edit your post as I could swear you said something about being told to put 2 winters on the front?
Winters all year are okay, as long as you don't mind the squirmy handling all summer and excessive tyre wear. You could argue that your summer braking is now compromised as the braking distance in summer will be longer with winter tyres but you should not be driving on the limit on public roads anyway so it should not make as much difference as the tyre tests suggest and the benefit in cold weather is much more significant.
Posted : 24/11/2018 1:01 pm
On my usual work commute there's one bit that catches people out with a 90 degree bend after a decent 60mph(+) stretch, it's probably 50/50 whether they end up forwards in the ditch, understeer, Vs backwards in the ditch, oversteer 😁
Posted : 24/11/2018 1:08 pm
Having been in a few oversteer incidents on the access road at work I can personally vouch for new to the rear as that stopped it happening. Never had the front at the point where the tyres couldn't cope.
Waiting on anecdote not data comment...
Posted : 24/11/2018 1:57 pm
@ andyl. No edit, as the point was not on topic I guess its easy to mix up points.I was initially writing about my thoughts, that front wheel skids are easier for esp to sort out. I know I often think a post says one thing and when reread I find I have misread the post. That's not meant to sound condescending.
The guy at Michelin said you will easily reach the limit of a summer tyre during a cold winter but you would have to try to exceed the limit of a winter tyre in a UK summer.
The Conti guy provided tech details, about relative performance of both in the wrong and correct seasons and finished by writing if it was his family car and he had to choose, he would have winter tyres.
Both companies clearly stated that it was not ideal though.
Posted : 24/11/2018 5:49 pm
<div class="bbp-reply-author">Superficial
<div class="bbp-author-role">
<div class="">Member</div>
</div>
</div>
<div class="bbp-reply-content">
I hadn’t appreciated that the rear tyres were so important on FWD cars. It’s pretty stupid, then, that the garage advised us to only use winter tyres on the front…
I've done this- with sensible allseasons on the back- and it worked great. For me. It's completely shit advice, though, because it might not work great for you and if it doesn't then someone's likely to get squished.
</div>
(basically, if you still drive cautiously and well within capability, and treat the extra grip as like a trump card you can use occasionally, it's a useful bonus. If you try and use that grip all the time, it's backwards through hedges. You need to drive almost all the time to the capability of the rears and it's constantly tempting even to a good driver to drive to the capability of the fronts.)
Posted : 24/11/2018 7:57 pm
What the ‘ell are you on about?
I agree with your working. But that's not what you said in the original post.
Although I'll concede you probably meant you have a longer time relative to rotating tyres, that reads that wearing a set of rear tyres out over ~40k (so 20k at less than 50%) is different to say 4x fronts at 10k intervals with 4x 5k = 20k at less than 50%.
Although it does raise a question, if the fronts are almost worn out and you new tyres on the back, does that tip the balance too far.
I've rotated my winter tyres as I reckon by next summer the better ones (now on the front) will be equal or worse than the rears.
Posted : 24/11/2018 9:09 pm
Having been in a few oversteer incidents on the access road at work I can personally vouch for new to the rear as that stopped it happening. Never had the front at the point where the tyres couldn’t cope.
I think whoever did that needs to learn to slow down .
Posted : 24/11/2018 10:41 pm
"I think whoever did that needs to learn to slow down"
Or if it's anything like the kind of access roads i use at work it's the perfect place for some fun being blocked off to the public , wide , clear , gravelly and with gates at either end that I have the keys to so won't meet anyone.
Hilux slidez (accidentily of course)
Still struggling to see any logic to not put the good ones on the rear.
Posted : 24/11/2018 10:48 pm
Perhaps in a safe environment when you want to push it, but on an open road just drive like a grown up?
Posted : 24/11/2018 11:41 pm
I put new rubber on the front of the mighty old Galaxy this morning. Rears are about half worn. I did ask about swapping them but they said fine as they are. A bit more wear on the rears he reckoned they would have recommended swapping them.
i used to it part worn second hand remoulds or anything tyre shaped on my motors but after having a blow out & rolling a car some years ago I don’t piss around with tyres.
Posted : 25/11/2018 12:12 am
Tina's - I said if you just keep replacing fronts ie fitting the new to the front all the time. And thus your rears will continue to wear slowly and thus be at low tread for longer, admittedly whenever they get there.
My little workings above show why it is more sensible to have new on the rear regardless of grip when new. Grip when old is probably even more important as you could be driving round for a few winters with rear tyres between 3mm and the legal limit which will mean they may not perform as well in standing water or with mud on the road.
Granted Michelin did do a study claiming their tyres performed right down to the limit in the wet but not sure how representative of all tyres, all cars and all conditions that is.
Thinking back tha might have been due to their straight cut tread unlike most tyres where the tread grooves taper so actually narrow towards the tyre carcass so as the tyre wears the groove that moves water gets narrower so in that initial contact you get less displacement. It is only when the groove cannot cope water volume wise that the depth comes into play.
Posted : 25/11/2018 4:10 am
"Perhaps in a safe environment when you want to push it, but on an open road just drive like a grown up?"
Surely the same  rule numbern1applies. Still doesnt excuse not utting the new tires on the back.but I've yet to sees decent arguement not to  - but there's also the you don't get lulled I to a false sense of security in that well the fronts are gripping so I'm good..... See it all the time In winter round here wjth the 2 winter tire bregade going off the road backwards when it let's go .
tndyl 'spoint<span style="font-size: 0.8rem;"> is the one for me though .i don't want to end up with 10 year old perished tires on the back of my car. Been in a van that's had a blow out due to exactly this ..... </span>
Rule number 1 is like ppe- it's the last line of defence not the first.
Posted : 25/11/2018 8:59 am
Or if it’s anything like the kind of access roads i use at work it’s the perfect place for some fun being blocked off to the public , wide , clear , gravelly and with gates at either end that I have the keys to so won’t meet anyone.
Na, it's a public road, with a cycle path crossing it. Lots of EDF employees treat it like a race track mind.
Posted : 25/11/2018 9:48 am
