New Kettle = Bad Te...
[Closed] New Kettle = Bad Tea
18 Users
After 10 years our trusty kettle had to flutter off to the great electrical scrap heap in the sky.
I got over that pretty quick but it's replacement is causing a slight tinge to the taste and ruins what should otherwise be a delicious tea. I am not really sure how I can go on. No-one should have to live with substandard tea...
Posted : 08/05/2016 7:36 am
Our new kettle at Xmas advised boiling and discarding a full kettle of water at least 3 times before making a cuppa.
Posted : 08/05/2016 8:08 am
Yep. Done that. Has been getting on for a week now 🙁
Posted : 08/05/2016 8:22 am
Maybe it was your old kettle that made tea taste funny.
Have you tried gin?
Posted : 08/05/2016 8:49 am
There's always Gin...
Posted : 08/05/2016 9:01 am
Buy some distilled vinegar (the clear stuff) fill kettle with 50/50 mix with water and boil. Then a couple of cycles of water. Worth a try, Mrs B swears by that as a cleaning agent
Posted : 08/05/2016 9:05 am
It's the tea....
Posted : 08/05/2016 9:26 am
Yorkshires finest? Really?
Posted : 08/05/2016 9:31 am
Might have a look into the vinegar thing although do wonder if it will make the tea taste like a chip shop. Is that a bad thing?...
Posted : 08/05/2016 9:33 am
Take it back and try a different model.
It is every British citizen's right to have a quality cup of tea!
May take the teabags and a mug and see if they will let me test them out before swapping
Posted : 08/05/2016 9:34 am
The vinegar thing is great for limescale removal (use white not malt). On a new kettle though, it shouldn't be scaled up! Is it metal or plastic?
Posted : 08/05/2016 10:01 am
nickc - Member
It's the tea....
POSTED 35 MINUTES AGO # REPORT-POST
mechanicaldope - Member
Well it's probably other going to matter how bad your water is, never had a good cup of Yorkshire tea
Posted : 08/05/2016 10:03 am
 Del
colleague bought the cheapest that tescos had that was still making tea taste bad 4 months later.
it mysteriously boiled dry one day.
now we have a nice bosch. perfect tea from the first.
Posted : 08/05/2016 11:57 am
Bicarbonate of soda sorted ours. If it's a plastic/glass/metal hybrid, it's the release agent that you can taste.
Posted : 08/05/2016 12:02 pm
It's a stainless steel Russell Hobbs Cambridge. Fairly cheap but it only has to boil water. How hard could that be?!
Posted : 08/05/2016 12:26 pm
A bloke I worked with complained about is funny tasting tea and coffee for a couple of weeks, when he was quizzed in depth it transpired he used the flex from his old kettle for the new one as it fitted perfectly.
He quite rightly assumed the flex for the new kettle was in the box and didn`t check.
It wasn't, the manufacturer had popped it inside a plastic bag in the kettle. So for 2 weeks he`d been stewing his flex in boiling water then drinking it with a slight coffee taste 😀 😀
Posted : 08/05/2016 1:33 pm
Brilliant. I thought that was going to be a mains leads matter story, like what hi-fi buffs imagine...
Posted : 08/05/2016 3:37 pm
What's the release agent?
Posted : 08/05/2016 5:11 pm
Picolax?
Posted : 08/05/2016 5:14 pm
Jizz.
Posted : 08/05/2016 5:25 pm
Release agents prevent adhesives from bonding to a surface.
In addition to the above, is the kettle actually boiling the water or just turning off when it's warm?
Can take a couple of weeks to break in a new kettle. There's probably a market in "broken-in" kettles.
Posted : 08/05/2016 6:03 pm
Release agent is also used to release the plastic part from the mould.
At least you've got a kettle. At work, that's to dangerous so we have a hot water supply, which is only, as you'd expect, hot, not boiling.
Posted : 08/05/2016 6:15 pm
Defo boiling. Just trying to power through and hope for the best until I can either pick up some vinegar or bicarb. We have one of those crappie water taps at work too. It's saving grace is that it is so unreliable we normally have a kettle out too.
Posted : 08/05/2016 7:10 pm
I was in the same situation and noticed this a few weeks ago. I can't notice it now. Either I've gotten used to it, or the taste has gone. All good either way.
Posted : 09/05/2016 6:51 am
