New Engine Mounts f...
[Closed] New Engine Mounts for a Corsa
4 Users
Just been told I need to replace the engine mounts on my old Corsa. Does anyone know if this is a expensive job?
Posted : 12/05/2011 12:14 pm
 robh
Probably depends on if they are cheap rubber jobs or hydraulic year and model may help, or google to find out, I had one replaced on an old Saab for about £75, replaced a couple on a fiesta they were about £3:50 each.
Posted : 12/05/2011 2:22 pm
Shouldn't be too hard to do yourself if you are reasonably competent with spanners etc.
Posted : 12/05/2011 2:25 pm
You might find there is a 'performance' mount (harder compound to reduce engine & gearbox movement with higher power outputs - more noise and harshness through car) available from an aftermarket supplier cheaper than the genuine item.
Just a thought.
Posted : 12/05/2011 5:04 pm
