Networking question...
[Closed] Networking question?
Looking to connect my Panasonic TX-42G15B tv to my router, only thing is the tv is not supported with USB and only Ethernet.
Can I use a Ethernet male to USB female connector to allow this, rather than hard wiring?
http://www.focalprice.com/CA430B/USB_A_Female_to_Ethernet_RJ45_Male_Router_Adapter_Black.html?Currency=GBP#.UUMoyYwgGSM
Posted : 15/03/2013 2:58 pm
By "router" do you mean "modem"? What is it?
Posted : 15/03/2013 3:00 pm
I'm not entirely sure what you're trying to do, but I can safely say its not going to work with that cable.
You want to use a standard Ethernet cable to connect your TV to your router - The USB port is of no use to you.
Posted : 15/03/2013 3:01 pm
Does your router have more than one lan (rj45) socket? If it does, just get a network cable an dplug the TV into that. If not, buy a cheap 4 port switch, plug that into your router and then plug your PC and TV into the switch
Posted : 15/03/2013 3:03 pm
sorry but what?
just use ethernet surly?
Posted : 15/03/2013 3:04 pm
Glad I'm not the only confused as ****! 😯
Apparently you can use them to turn a usb device into an iP device.. Eg Printer into a network printer... Personally I'm sceptical about this.
Only thing I could think offhand was that the OP has an old USB dial-on-demand ADSL modem rather than a modern router.
You and me both. Seems a remarkably clever thing to do for a sub-£2 adapter.
Posted : 15/03/2013 3:12 pm
Yes I know I can connect with cable but router/modem is 8-10 metres away and would involve lifting carpet and other hassle.
Router/modem is Netgear N300
Posted : 15/03/2013 3:13 pm
So... how does USB help?
Posted : 15/03/2013 3:15 pm
Wait, are you talking about plugging a USB WiFi dongle into it?
Sorry..yes
Was gonna connect tv to router/modem via wireless USB adaptor plugged into the USB adaptor- Ethernet adaptor.
If that makes sense?
Posted : 15/03/2013 3:18 pm
EDIT: Too slow. Can you get a wiFi dongle for your TV?
No tv not compat.
Posted : 15/03/2013 3:19 pm
I think what you need is something this:
http://www.amazon.co.uk/NETGEAR-WNCE2001-Ethernet-Wireless-Adapter/dp/B003D0WZKC
Daisy-chaining dongles like that is going to, well, let's say it's going to be unpredictable. There's an outside chance it might work I suppose but I'd be shocked if it did.
Posted : 15/03/2013 3:20 pm
Cougar- that makes sense.
Eth - Eth into bridge adaptor then hey presto!
Nice one cheers!
Could you not just buy another wireless AP/Bridge and plug that directly nto TV with cat5
Posted : 15/03/2013 3:21 pm
ah hang on a sec...
so this usb-rj45 goes into the the network plug on the tv.
then a wireless dongle into the usb?
how will you program the dongle?
I very much don't think this will work
careful and considerate cable mangement will solve this
I suggest buying a rasperry Pi.
Cheers but I don't think so as you can tell computers and associated sh*t ain't my strong point 😀
Posted : 15/03/2013 3:24 pm
I'd be looking at powerline adaptors for that if you have a power socket at both ends.
http://www.misco.co.uk/Product/127767/NETGEAR-Powerline-85Mbps-Network-Adapter-Kit
If power sockets are at a premium, you can also get pass-through models to enable you to still use the socket for power for a bit more £.
Posted : 15/03/2013 3:25 pm
buy 8-10 meters of rj45. and run it carefully to the TV
How about a homeplug?
eg http://www.amazon.co.uk/TP-Link-PA411KIT-AV500-Powerline-Adapter/dp/B0084Y9N3O/ref=dp_ob_title_ce
Do this. It's what my parents have set up in their house. Ethernet on tv -> homeplug 1, homeplug 2 -> router. Sorted.
Posted : 15/03/2013 3:33 pm
Yes that does - you can get a wireless adapter that plugs into the ethernet and is powered by USB from Netgear:
http://www.netgear.co.uk/home/products/hometheater/networking-for-home-theater-and-gaming/WNCE3001.aspx#
Greeble you are missing the point and stating the obvious!
To all that have answered my question and offered solutions and not stated the obvious, Thank you!
Posted : 15/03/2013 3:35 pm
sometimes the obvious soluition is the best/cheapest/easiest solution
Posted : 15/03/2013 3:39 pm
No sh*t Sherlock!
Posted : 15/03/2013 3:40 pm
then why not use rj45 and be creative with your routing so you don't have to lift up carpet etc......
Posted : 15/03/2013 3:42 pm
It must have wireless surely? Be daft if it didn't.
Posted : 15/03/2013 3:51 pm
no that TV doesn't.
Posted : 15/03/2013 3:54 pm
