Name this lanyard c...
[Closed] Name this lanyard connector
Need to buy a few small lanyards with these connectors but have no idea what they are called and my Googlefu is failing me
https://flic.kr/p/2muG2WZ
Posted : 26/09/2021 6:50 pm
Quick release buckles.
Breakaway clips.
Posted : 26/09/2021 6:57 pm
Proper name is Side release buckle.
They’re safety connectors or release so that folks don’t strangle themselves should they get caught on rotating machinery or shaggy things - practically all lanyards come with them - often just called ‘safety lanyard’
Mini QR Loop/Buckle? https://www.ebay.co.uk/p/2061068016
Posted : 26/09/2021 6:58 pm
Cheers for the replies
Searching using Mini QR Loop/Buckle lanyard has yielded the perfect result
10 of exactly what i need for £4
https://www.amazon.co.uk/gp/product/B00BNCDCW2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Posted : 26/09/2021 8:30 pm
" They’re safety connectors or release so that folks don’t strangle themselves should they get caught on rotating machinery or shaggy things – practically all lanyards come with them – often just called ‘safety lanyard’"
<span style="font-size: 0.8rem;">It just allows the thing on the end of the lanyard to be removed. It doesn't stop you getting strangled if either a machine or a person grabs the lanyard itself.</span>
Posted : 26/09/2021 9:44 pm
Lanyards should have a safety breakaway clip in them, one that breaks apart with far less pull than that one.
....Rotating machinery and things that dangle......
(Just making a statement, dont actually know what the OP use is though)
Posted : 27/09/2021 11:00 am
Just to clarify these are being used so i can swap camera's and lights between bikes/helmets but not have to unravel/remove the lanyard each time as each bike/helmet will have its own lanyard attached and i just need to clip on the camera/light to whatever bike/helmet id be using
I have to wear a proper break away lanyard for work (work with large industrial machinery)
Our company state they must have to have a break away clip at the top of the lanyard so its at the back of your neck, so if the lanyard gets caught in a machine the whole lanyard will come off your neck easily and not leave anything else around your neck that could drag you into the machine
Posted : 27/09/2021 12:22 pm
