MySQL SELECT from m...
[Closed] MySQL SELECT from multiple table doing my head in.
 PJay
I've been slowly trying to learn a bit of php and MySQL and have written a small script to read the first few topics from a phpbb forum database to display on the homepage. I'm finding MySQL a struggle but have manged to select data from two seperate tables, phpbb_posts (where I've selected all the data) and topic_id and topic_name from phpbb_topics, [b]where[/b] the topic_id in the post table matches topic_id in the topics table (it took a while but I was actually quite pleased by this). The actual selet statement is:
$result = mysql_query("SELECT phpbb_posts.*, phpbb_topics.topic_title, phpbb_topics.topic_replies FROM phpbb_posts, phpbb_topics WHERE phpbb_posts.topic_id = phpbb_topics.topic_id ORDER BY post_time DESC LIMIT 50");
Now I want to take things a bit further. The phpbb_topics table holds a value forum_id which matches forum_id in the php_forums table. I want to extract data from the phpbb_forums table based on the forum_id in the phpbb_topics table matched to the topics_id in the php_posts table.
In psuedo-plain English the logic is fairly straight forward - I want to [b]select[/b] all the fields in the phpbb_posts table and phpbb.topics_topic_id and phpbb_topics.topic_name from the phpbb_topics table[b] where[/b] phpbb_posts.topic_id matches phpbb_topics.topic_id [b]and[/b] the phpbb_forums.forum_id and phpbb_forums.forum_name [b]where[/b] phpbb_forums.forum_id [b]=[/b] phpbb_topics.forum_id
but I just can't work out how to write this correctly in MySQL. I feel that an AND is needed somewhere and possibly a second where clause, but I seem to have drawn a blank. I've tried looking at the online MySQL manual before asking people, but to a newbie it's pretty heavy going.
Am I on the write tracks and could someone give me some pointers?
Posted : 16/03/2010 4:30 pm
Does MYSQL support ANSI joins?
Hated them at first but these days separating joins form your conditions makes more sense to me.
Posted : 16/03/2010 4:36 pm
you need a join in there somewhere I reckon.
Posted : 16/03/2010 4:37 pm
1) put phpbb_posts as po, phpbb_topics as top and use the abbrieviations
2) you can only have one "where" but say (condition_a) and (condition_b) after it
select po.*,fo.forum_name from phpbb_posts as po, phpbb_topics as top, phpbb_forums as fo where po.topic_id=top.topic_id and fo.forum_id = top.forum_id etc
or even neater, use a join
Posted : 16/03/2010 4:40 pm
Not really understanding what you're asking, but ANSI version would be something like this:
SELECT
phpbb_posts.*,
phpbb_topics.topic_id,
phpbb_topics.topic_name,
FROM phpbb_posts
JOIN phpbb_topics ON phpbb_posts.topic_id = phpbb_topics.topic_id
JOIN phpbb_forums ON phpbb_forums.forum_id = phpbb_topics.forum_id
Posted : 16/03/2010 4:41 pm
Your original query:-
At a guess becomes this:-
phpbb_topics.topic_replies,
phpbb_forums.forum_id,
FROM phpbb_posts, phpbb_topics, phpbb_forums
AND phpbb_forums.forum_id = phpbb_topics.forum_id
I'm assuming a straightforward table structure of:-
FORUM --< TOPIC --< POSTS
You might want to consider using table alias' as well as it makes
the SQL more readable.
SELECT pp.*,
pt.topic_title,
pt.topic_replies,
pf.forum_id,
pf.forum_name
FROM phpbb_posts pp,
phpbb_topics pt,
phpbb_forums pf
WHERE pp.topic_id = pt.topic_id
AND pf.forum_id = pt.forum_id
ORDER BY pp.post_time DESC LIMIT 50
Posted : 16/03/2010 4:43 pm
 PJay
Thanks, I'll have a play. I haven't got as far as JOIN yet, I'm finding the whole thing rather heavy going I'm not really cut out to be a programmer but I ought to be able to work it out if I go slowly.
HTTP404's solution is pretty much what I was thinking (without having looked at JOINs) but I do think I see how the JOIN thingy works too.
Posted : 16/03/2010 4:48 pm
hmmm something like this?
select phpbb_posts.* , phpbb.topics_topic_id , phpbb_topics.topic_name
from the phpbb_topics, phpbb , phpbb_topics
where phpbb_posts.topic_id = phpbb_topics.topic_id
and
phpbb_forums.forum_id = phpbb_forums.forum_name
and
Thats assuming phpbb.topics_topic_id is a field in table phpBB but that looks like the database name to me....
Hard to see what you want without a look at the tables...
The "Joiney" thing operates on the the intersection of a union.
If you remember Venn diagrams? or look at one it's fairly self-explanatory.
Posted : 16/03/2010 4:53 pm
 PJay
$result = mysql_query("[b]SELECT[/b] phpbb_posts.*, phpbb_topics.topic_title, phpbb_topics.topic_replies,phpbb_forums.forum_id,phpbb_forums.forum_name
[b]FROM[/b] phpbb_posts, phpbb_topics, phpbb_forums [b]WHERE[/b] phpbb_posts.topic_id = phpbb_topics.topic_id [b]AND[/b] phpbb_topics.forum_id = phpbb_forums.forum_id
[b]ORDER BY[/b] post_time DESC LIMIT 50");
Seems to do the trick, although I'll need to do a bit of testing, and I do understand the logic there, I'll need to explore JOINs too though I suspect. Maybe it was a bit foolish to leap in and try and write a real-world solution (albeit a very simple one) and try and work out what to do as I went along but I do seem to remember things a little easier when I've worked out what to do rather than just followed examples in a book. I don't think I'm ever going to be very good at this sort of stuff though.
Thanks for the help.
Posted : 16/03/2010 5:03 pm
Not foolish at all, if you have no [i]need[/i] to do it, it doesn't get done (usually).
Posted : 16/03/2010 5:05 pm
Understanding the structure of your tables and structuring them relationally (ie using primary / foreign keys) - the rest just comes with a little practice.
and use table alias' in your sql. ๐Ÿ˜€
Posted : 16/03/2010 5:06 pm
