Multi-material circ...
Multi-material circular saw blades
I've got a cheapo sliding mitre saw that I only use to cut up stuff for firewood and it's probably due a new blade.
I may have a requirement to make about 20 cuts in some 3mm wall thickness steel tube - would a multi-material blade be Ok for that as well as chopping up my old waste wood?
Or would I be better to stick with a cutoff disc in the angle grinder?
Posted : 30/10/2025 12:11 pm
I've had a multi-material blade in my mitre saw since I bought it (an Evolution one) - still cuts all materials very well after many years of use.
Posted : 30/10/2025 12:24 pm
Posted by: fossy
Same here. It also cuts aluminium very well, as the fence will attest when I forgot to slide it out of the way on a compound mitre cut 🤣
Posted : 30/10/2025 12:39 pm
 mos
I think timber type circ saws run a bit faster than the evolution ones but for 3mm should be fine.
Posted : 30/10/2025 1:52 pm
Based on recent experience of building a gate. After about 10 shots at 3mm wall steel. That blade will be mince. It'll still cut eventually and smeary But you'll fit a new one and wonder what the **** you were doing .
It is very easy to use those TCT blades long beyond their safe useful life.
But they will give much better control over angle and repeatability of cut.
Posted : 30/10/2025 2:54 pm
Check out the saw speed and maximum blade speed. The evolution blades are rated to about 5000rpm but a lot of regular wood blades run to over 9000rpm. A burst blade at those speed will hurt a lot!
Posted : 31/10/2025 10:11 am
my Diablo blade is still going strong after 5+ years of timber cutting and occasional metal or scrap wood with embedded nails
I do find Diablo hard to come by in England, but I’m sure Evolution will have an equivalent multimateral blade
EDIT: Cannot upload a photo (ad nauseam) so here’s a weblink to the style of blade www.diablotools.com/products/D0736GPA
Posted : 31/10/2025 10:37 am
