Motorcycle electric...
[Closed] Motorcycle electrics - helppppp!
4 Users
Seems I'm suffering from a common Triumph problem, a knackered regulator/rectifier. Can anybody tell me if a faulty reg/rec would get hot (mine is), and is it a sign of problems if the wiring to it is getting very warm??
Posted : 26/06/2011 12:52 pm
My Daytona had similar problems.
I think the Reg/Rect will get hot in normal operation - the wiring getting hot is because Triumph spec wire that is a bit on the light side for the currents involved. I applied the modification described here: [url= http://www.triumphrat.net/daytona-deliberations/68041-weak-charging-system-the-solution.html ]linky[/url] and it seemed to help things a lot (wires cool and charging voltage up from 12.9 -> 13.7 or so, from memory).
Posted : 26/06/2011 1:29 pm
Yes it may melt and there is a fire risk eventually.
Overcharging may cause rotten egg smell from battery. Bulbs may blow.
Stick a voltmeter on the batteryy to se what you are getting. more than 14 you should be concerned.
Mine was making 19 volts and ended up quite crispy.
Posted : 26/06/2011 1:52 pm
Thanks euain.
Posted : 26/06/2011 1:54 pm
They often fail because of corroded plugs in the circuit. It's worth having a look at the plugs between the regulator and the alternator, chances are they're corroded. If you just replaced the regulator you may still have the problem.
Posted : 26/06/2011 2:15 pm
