More Excel Help...
[Closed] More Excel Help...
5 Users
I have a table in Excel which is the result of an SQL query (which has a parameter that can change)
E.g.
Columns A, B, C, D
Sorted on Column D.
I would like to colour in each row based on the value in Column A.
[b]A B C D [/b]
c x x 1
d y y 1
c z z 2
e a a 2
So, rows 1 & 3 to have the same colour, and rows 2 & 4 to have their own colours.
I could do it with a bunch of conditional formatting rules, but it would have to be redone each time the table was refreshed.
Anybody got any bright ideas?
Posted : 24/03/2017 5:09 pm
probably solvable with NAMED RANGES.
ALthough why not just conditional formatting? Have you got loads of options in A?
Posted : 24/03/2017 5:15 pm
Yes, loads of potential values in A.
Will conditional formatting stick around if I refresh the table? I wouldn't mind (too much) doing it once if it stuck...
Posted : 24/03/2017 5:17 pm
yes, conditional formatting is a format characteristic, so assuming the sql population is data only (or referenced) it shouldnt change any formats
Posted : 24/03/2017 5:18 pm
Cheers. Job for Monday 🙂
Posted : 24/03/2017 5:20 pm
Either that or vba to create a function for the sheet. It was beyond my abilities. Might have an example at work but can't promise
Posted : 24/03/2017 6:31 pm
 poly
Be aware that there is an upper limit to the number of formats you can apply (changed with version of Excel too, to make it hard to predict!)
Posted : 24/03/2017 6:42 pm
When they "improved" the conditional formatting function a few generations ago, they made it harder to manage, IMO. It always seems to create a gazillion separate rules to replace the one you create for a range. And it can go really screwy if you sort or move things around.
I'd favour a VBA approach here.
Posted : 24/03/2017 8:14 pm
