Mini Dv Cam Questio...
[Closed] Mini Dv Cam Question
Hi i recently made a video using the Mini DV Cam from the net.
I got 17mins and my 2gig card has run out of space.
Anyone else had that much space taken in such a short time, is there a way to compress it on the cam itself so its not so huge?
Many Thanks
Nick
Posted : 01/02/2010 2:51 pm
Er Mini DV is the tapes. If you are saving video to card then it's soemthing else. See if there are any settings for reduced quality on the camera or get a bigger memory card.
RTFM always helps ๐Ÿ™‚
Posted : 01/02/2010 4:03 pm
The Mini DV cams do seem to use a lot of storage but 2gigs for 17 mins seems excessive! They have no controls to change resolution/qualify to reduce size unfortunately. I've got a 4gB card in mine but the poor battery life means I haven't really used it in anger.
Posted : 01/02/2010 4:20 pm
Averaging out footage I've taken so far my 8GB card should be about 2 hours.
Posted : 01/02/2010 4:55 pm
Presumably taking about the recent eBay purchases, which were a DV Cam that was mini, rather than a Cam that used Mini DV.
Posted : 01/02/2010 6:14 pm
yes sorry for the confusion.
right i may have to buy a new card again then.
the quality i cant fault! battery life i dont no because i only have 17 mins lol
nikc
Posted : 01/02/2010 6:33 pm
 jeff
I'm seeing similar file sizes but not quite as bad!
Posted : 01/02/2010 7:26 pm
I get about 15 mins to about 1.5 gb (running an 8gb class 6 card) here gents. Used mine at the weekend to test at cannock. Very good video all things told. Im working on a mod for extra battery life (mini usb to battery pack in the rucksack) - but to be honest its not too bad. Give it a good charge before you go out on your bike. I'd say at least 4 hours.
My mate got nearly an hour on his. Its easily achievable if you charge long enough.
Posted : 02/02/2010 12:28 am
you got a link for your 8gb 6spd class card?
many thanks
Posted : 02/02/2010 6:51 pm
I don't have a link for his card exactly but you could [url= http://www.amazon.co.uk/Transcend-microSDHC-Memory-adapter-TS8GUSDHC6/dp/B001IAMME8/ref=sr_1_2?ie=UTF8&s=electronics&qid=1265142603&sr=1-2 ]get one from Amazon[/url].
HTH.
Posted : 02/02/2010 9:34 pm
