Migraines WTF
[Closed] Migraines WTF
 DrP
[i]If you have a clicky jaw it's probably your TM joint dislocating as you close your mouth. This puts all the muscles across your skull into spasm with the result being lots of and lots of headaches, neck pain and so on...[/i]
No doubt this sort of issue can aggravate muscular/tension type headaches, but migraines are felt to be a vascular process which is unlikely to be affected by the TMJ (as far as my readings have suggested).
This isn't saying tension type headaches aren't bad, just that they're not migraines.
I'm a migraine sufferer, and interestingly my pattern has changed as I got older - the number decreased, but developed the typical 'aura' before the headache.
The key thing about diagnosing migraine is how disabling they are - you simply cannot function with a migraine, fact! I did have triptans for a bit, but they simply knocked me out for as long as the headache would, just without the pain.... I gave up on them as the net result was 24hrs of my life wasted with or without the pills!
Interestingly, for cluster headaches, high flow oxygen has shown to be beneficial too!
DrP
Posted : 08/06/2011 8:41 am
Mrs Grips gets migranes, however only one proper one since we've been married. She called me saying she was poorly. So I came home from work to find her eventually hiding in the wardrobe in our room, because it was the quietest place she could find (the entire house was very quiet by normal standards). Phonophobia is one of her symptoms. Not helped by me wandering around the house bellowing 'HELLO? WHERE ARE YOU?' at the top of my lungs...
Posted : 08/06/2011 8:50 am
Indeed it has, but sadly only as an abortive treatment, best I have found in that respect so far are the Sumatriptan injections
Posted : 08/06/2011 9:38 am
You bastard!
Posted : 08/06/2011 10:41 am
It should be noted that I did not know about the phonophobia beforehand! I was not being a git... Migranes are not a joke...
Posted : 08/06/2011 10:44 am
Page 2 / 2
