I need some help with finding/identifying missing customer accounts from a master list. I have a Master list of our customers agreements. A second shorter list is of those customers with outstanding orders and a third even shorter list of those orders processed.
Somehow List two and three don't add up to the whole Master list. Some accounts aren't on either list. I need to find them quickly and easily.
Is there an Excel equation that can run on the Master list and check the other lists for the same agreement number and then if not found mark itself somehow?
Thanks,
VLOOKUP is probably your friend here, assuming the customer name / reference number is unique and consistently used accross the lists
This is one of those questions where vlookup will actually help you.
edit: Beaten by cheesy - make it easier by sorting ascending on the field you are going to use with the vlookup
Although I'd recommend moving to a better integrated/relational way of managing this information in the future.
I think i'd be using COUNTIF but VLOOKUP could be made to work
use IF and ISERROR with VLOOKUP to handle #N/A that return from missing account numbers.
