Mesh wifi setup ......
Mesh wifi setup ... talk to me , cant print ?
I've had a Tenda nova mw 3 setup for the last 12 months , mainly to get Wi-Fi into the garage for Zwift etc , while its worked in a fashion getting WIFI around the house , I've never managed to get a printer to work while the mesh is plugged in , I can print when its knocked off etc
the mesh system has same network SSID and password as the plusnet router as recommended but still not playing nicely ?
I've even dropped all firewalls incase that's stopping it but didn't make a difference
any ideas or advise from techy peeps would be appreciated
Posted : 15/12/2022 8:51 pm
Change the SSID on your mesh and then connect everything to that.
Posted : 15/12/2022 9:00 pm
Is it a WiFi printer?
Posted : 15/12/2022 9:11 pm
onewheelgood
yes ...... sorry forgot to say that
Posted : 15/12/2022 9:13 pm
Yes, and the next step is turn off the Wi-Fi on the Plusnet router or change its SSID. Then you can be sure the printer is on the same network as the client.
Posted : 15/12/2022 9:14 pm
different subnets init.
set the tenda to bridge mode or it creates its own network on a different subnet.
Posted : 15/12/2022 9:26 pm
what band are you broadcasting on?
My printers don't work on 5 Ghz
mrmoofo
My printers don’t work on 5 Ghz
printers on 2.4
Posted : 15/12/2022 9:41 pm
 StuF
my hp printer doesn't work on 5Ghz or mixed 2.4 / 5GHz either - had to set up a separate network on just 2.4Ghz then it works fine - it's just a pain to print from as you have to swap onto the guest network if you want to print
Posted : 15/12/2022 9:46 pm
