MacBook Air - Cut a...
[Closed] MacBook Air - Cut and paste photo URL to paste into IMG on STW help please !!!
Ok, I'm out and about today and only have my macbook air without a mouse and I am trying to write an ad here and put some piccies on the ad. I have the photos in my picasaweb account and what I normally do is use the right click mouse to cut the IMG URL and then paste it into my ad in the IMG tab. I only have a trackpad and can't seem to do cut and paste of the URL on that !
Any help ??? I am really struggling with this aspect of the otherwise brilliant MacBook Air !
Posted : 13/06/2013 12:48 pm
get a [s]pen[/s] sorry mac user i meant Crayon and write done the url and then type it in
Bet it is quicker
Posted : 13/06/2013 12:49 pm
Command + X should be Cut
Command + V should be Paste
Command key also known as the Apple key, to the left [and perhaps right] of the Spacebar
Posted : 13/06/2013 12:54 pm
You can set tap to left click & click to right click on your track pad.
Posted : 13/06/2013 12:56 pm
Yeah, I know those shortcuts, but what happens is you normally need to right click over the photo and copy that, without a mouse you can't do that and it isn't the URL that appears in the task bar at the top of the screen.
Anyone else ???
Posted : 13/06/2013 12:57 pm
click on the trackpad with TWO fingers
http://support.apple.com/kb/ht3211
Posted : 13/06/2013 1:00 pm
Two finger trackpad press is same as right click isn't it?
Or use the shortcut keys once you have made the selection.
Edit - beaten to it! You do know about two fingered scroll and stuff right?
[url= http://www.apple.com/uk/osx/what-is/gestures.html ]http://www.apple.com/uk/osx/what-is/gestures.html[/url]
Posted : 13/06/2013 1:01 pm
Hold Control and click on the image?
http://www.wikihow.com/Right-Click-on-a-Mac
Double tap to highlight then right click?
Posted : 13/06/2013 1:04 pm
(Mandatory) http://www.dell.co.uk/outlet/
No - wait!
Ask the barista 😉
Posted : 13/06/2013 1:06 pm
writing it down would have worked by now 😛
Wooohooooo ! I was just coming on to say I had found the CTRL click thing ! Now the MBA is even more perfecter !!!
Oh ye PC users of little faith !!!
Whoop !
Thanks all
Posted : 13/06/2013 1:10 pm
Two finger click is same as right click
Posted : 13/06/2013 1:14 pm
This has to be a troll, right?
Posted : 13/06/2013 1:15 pm
You may have to set up the two-finger tap as right (secondary) click in System Preferences. It's certainly an option and I can't remember what the default is.
Posted : 13/06/2013 1:41 pm
Nope, not a troll, just loving the usual helpful STW'ers. Great bunch, always can find an answer to the most obscure shit on here !
Thanks guys
Posted : 13/06/2013 2:17 pm
Command + C should be Cut
Posted : 13/06/2013 2:20 pm
Tried holding Shift while hitting minimise or using Exposé?
OR
Control + Option + Command + 8
[You'll need that twice I bet - I know it's changed in the last couple of releases of OS X so it may not work on your machine]
Posted : 13/06/2013 2:39 pm
Hey, that works on my PC too! (windows 8 laptop)
Much slicker than using the right click.
Posted : 13/06/2013 2:51 pm
Assuming it follows the same conventions as a PC, 'C' is copy, not cut. 'X' is cut (looks a bit like scissors, see?)
Well you've got me there. The MBA does indeed have a right click, pure technological perfection.
Posted : 13/06/2013 2:55 pm
Bring back Macintosh Basics!
Posted : 13/06/2013 3:04 pm
 IA
You can set it (might be default?) so a click on the bottom right of the trackpad is a right click too.
Posted : 13/06/2013 3:18 pm
Ooops I read that as copy. 😳
CMD + X doesn't work by default it's even greyed out on the menu bar.
Posted : 13/06/2013 3:26 pm
