Loftzone Decking Ki...
[Closed] Loftzone Decking Kits
Anyone used a decking kit from Loftzone for storage in the roof space?
Whats the quality/ease of fitting like?
Anything better or as good but cheaper?
Posted : 21/01/2021 12:50 pm
We used them in our loft.
They’re easy enough to install but despite following the instructions they don’t seem overly sturdy!
Posted : 21/01/2021 7:24 pm
Cheers for the reply.
In what way are they not sturdy?
Posted : 21/01/2021 9:21 pm
They seem to flex and move a lot when you step on them. I've also found that the boards sag quite badly despite having very little weight on them.
Posted : 21/01/2021 10:27 pm
Mmmm. Not very impressive then.
Posted : 21/01/2021 10:28 pm
I'm also looking at this as an option, did you use their boards or something else? They recommend 18mm boards as a minimum with 600-610mm spacing on the supports, is this how they were fitted?
Thanks,
Posted : 21/01/2021 11:42 pm
I used them but as others said I found them relatively flimsy and wouldn't use them again. I only used the legs and put them on every joist, along with tongue and groove chipboard sheets.
There are more robust and cheaper options available which I'd use if I did it again.
Posted : 22/01/2021 10:41 am
 5lab
I used loftlegs in my current gaff, with lots of packs of the t&g loft floor packs from bnq\wickes (the ones that are 4'x1'). T&G the floor together, and interleave them so no join lines up with no other join. I have 600mm joist spacing and have never thought it feels flimsey in any way (other than during assembly - once its up its rock solid). I haven't tried jumping on it, but there's no sag underfoot. I'd reccomend, along with an impact driver to make very light work of screwing everything together
edit - the one thing I'd add is access to the lower screw holes is a little tight - a lot easier with a longer driver bit and/or an extension just to get the body of your screwdriver further away from the leg
Posted : 22/01/2021 10:53 am
As above I used Wickes loft legs/tongue and groove board in the autumn. Very solid I’d say.
Took most of a weekend to do it on my own and a fair amount of effort!
I had an extension bar in the drill and prefitted screws to the legs. Still got 1/3 of it to do when I can be bothered..
Posted : 22/01/2021 11:08 am
I also used the Wickes Loft legs & tongue & grove boards, a lot of screwing, but gave me the ability to board a small space around our chimney & have no complaints with it at all.
Posted : 22/01/2021 11:49 am
We have the Loftzone stuff in our loft.
Got a local installer to do it for us as I'm crap at that sort of stuff and it needed the hatch widening and a ladder installing.
Didn't take them long to do it, it seems really good stuff - I kept going and having a look at it when they were on breaks etc.
Posted : 22/01/2021 11:57 am
