large format fade f...
[Closed] large format fade free printing ?
11 Users
Need to print some items for outside use (enclosed in poster holder), the old ones have faded in the sun.
Normally use std paper on a roll, is it just paper I need or special inks aswell ? HP DJ510 plotter so had a look on the HP site and found a roll called 'HP Durable Banner with DuPont Tyvek'.
Posted : 03/06/2011 9:22 am
You would need a solvent type of ink in order for it not to fade .
Posted : 03/06/2011 10:02 am
They all fade over time (some are just more resistant) - how long do you need it to resist for?
Might be better finding an online service that offer a speciality service?
Posted : 03/06/2011 10:12 am
We have some print suppliers which Ive asked for a quote. The prints may need to be changed at random so would have liked to have done the printing myself but the HP paper roll is 15 times more expensive than normal ( plus any ink )
Posted : 03/06/2011 10:18 am
You would need to talk to them about your specific application but we used to use this product to extend the life of printed vinyl that was in a particularly bad enviroment.
http://www.victorydesign.co.uk/categories/name/frogjuice
We used to use it on vehicles for hire companies etc. that get jest washed with chemicals several times a week. Yes the ink was solvent based but it did definately make a difference.
I would have thought in your case if you can already print them yourself it would be worth a go for quite a small outlay for a can. Need a very well ventilated place to apply it and let it dry.
Posted : 03/06/2011 10:49 am
If you can get pigment inks for your printer they will fade less than the dye inks, some of the new HP large format printers use vivera pigment inks which have a 100 year life span, you might be able to get some aftermarket/copy pigment inks?
But if the posters are in direct sunlight, your best option is solvent inks on vinyl as mentioned above.
Here have a look at some of these(below), you'll need to do a bit of research, into UV dye, pigment etc
hp designjet 510 pigment inks google link
http://www.google.co.uk/webhp?hl=en#hl=en&xhr=t&q=hp+designjet+510+pigment+inks&cp=29&pq=hp%20designjet%20510&pf=p&sclient=psy&site=webhp&source=hp&aq=f&aqi=&aql=&oq=hp+designjet+510+pigment+inks&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=eb847c1bda400d6d&biw=1366&bih=635
Posted : 03/06/2011 11:08 am
You could also look at encapsulating in UV resistant film so the plastic cover protects from the sun rather than the inks/substrate.
Just a thought.
Posted : 03/06/2011 11:32 am
m_f nails it in 'thinking outside the pyramid shocker'
What wavelength UV?
Posted : 03/06/2011 2:26 pm
I'd talk to the printers. We use jamjar and they are super helpful, great guys. No complaints on anything fading too quick but it is pretty much an unavoidable eventuality.
Posted : 03/06/2011 2:31 pm
is this a sign for stickman?
Posted : 03/06/2011 2:48 pm
No, sick men (DYSWIDT).
Posted : 03/06/2011 2:51 pm
Y, ID
Posted : 03/06/2011 5:35 pm
No time to get all misty eyed and philosophical
Posted : 04/08/2011 1:03 pm
ooh. bot-tastic.
Posted : 04/08/2011 1:05 pm
dagnabit
EDIT..... actually, possibly not
EDIT EDIT....... changed my mind. definately.
Posted : 04/08/2011 1:34 pm
