Lap top screen may ...
[Closed] Lap top screen may have died. Anything I can try?
My laptop screen isn't coming on, the fan is running and the green lights are on.
It's nothing fancy a Fujitsu Siemens Amilo.
Is there anything I can try at home?
Posted : 26/01/2012 2:49 pm
you haven't switched it to use an external monitor not the laptop screen itself have you?
Posted : 26/01/2012 2:50 pm
What would I have done to do that?
EDIT I pulled out all the cables, counted to ten, put them back and it has fired up again. Thanks
Posted : 26/01/2012 2:51 pm
Fn+F3 together on the dead Amilo Pro under my desk.
Edit: see it's sorted now.
Posted : 26/01/2012 2:56 pm
schoolboy error on my part ๐Ÿ™‚
always ask "have you switched it off and back on again?" before anything else...
Posted : 26/01/2012 3:00 pm
...in which case, do you have access to a secondary screen - plug it into that and switch the output to it to check if the lappy screen is the problem or not?
Posted : 26/01/2012 3:03 pm
