KickStarter: CydeKi...
[Closed] KickStarter: CydeKick - a frictionless dynamo with USB output
19 Users
Still in draft at the moment (launches at the end of the month) but this looks quite promising.
[img] ?v=1434835871&w=680&fit=max&auto=format&q=92&s=88addde45d9cdcc06c57be2e78c54323[/img]
https://www.kickstarter.com/projects/198686882/1754746434?token=c053ce5d
Uses magnets (how do they work??) to generate power which you can use to power a light and recharge your phone/GoPro/roadcam etc.
What say the naysayers?
Posted : 23/07/2015 10:30 am
 MSP
It sounds like they are just externalising the internal workings of a dynamo hub.
Posted : 23/07/2015 10:35 am
Yep - but that's a good thing because it means you can fit it to any bike rather than getting a wheel built up with a special hub.
Posted : 23/07/2015 10:37 am
Yeah, and making a knock off of the B&M lights with USB output.
And making the dynamo in such a way that you can't run a disc brake with it.
I'm out.
What's the projected cost of the full system? Will it be cheaper than an entry level hub plus light? (plus build/spokes if you're feeling generous)
Posted : 23/07/2015 10:40 am
You can fit it to the front wheel on the non-disc side surely?
Posted : 23/07/2015 10:42 am
The KickStarter page has the lights-only mini-system for a pledge of $150 (USD) and the usb+lights system for a pledge of $275
So if those reflect the retail price then it'll be a bit pricier than a dynamo hub + wheel build.
Posted : 23/07/2015 10:48 am
Frictionless? Snake oil right there. I'm out.
And how will it stand up to a wet winters ride?
Posted : 23/07/2015 10:49 am
Hmmm, so a pricier uglier solution probably come up with by someone who has not tried a decent dynamo hub system...
I'm still out. Seems a pity if they've put a lot of effort into it.
Posted : 23/07/2015 10:51 am
If only someone like Sturmey Archer had thought of this 80 years ago ...
Yeah that's the biggest concern for me - looks great on hipsters in sunny Miami. Might struggle a bit in freezing salty road clag. 😀
Posted : 23/07/2015 10:53 am
Prior art? Got links?
Posted : 23/07/2015 10:54 am
No Added Friction
Bollocks.
Clearly don't know what they're talking about, they might as well claim to have invented a perpetual motion generator.
Posted : 23/07/2015 10:56 am
Demo video is hardly inspiring, the LED front light is barely visible!
Surely you jest?
[url= https://en.wikipedia.org/wiki/Hub_dynamo ]https://en.wikipedia.org/wiki/Hub_dynamo[/url]
It's basically a motorcycle stator, isn't it? There's no mechanical friction in the generator bit itself but there'll still be a resistance felt due to the... gaaah... A-level physics don't fail me now... back EMF (I think). There's still mechanical friction in the bearings and stuff.
Posted : 23/07/2015 11:04 am
Surely you jest?
Right, but this isn't a hub dynamo though - most notably because it's not in a hub. So I think it would probably pass a uniqueness test for a patent.
Posted : 23/07/2015 11:06 am
Bin done.
http://intelligentdesigncycles.com/product/sunup-eco-ds-1r-spoke-dynamo
Connects to proper lights too as its a proper dynamo.
Not to mention these ones you can get in most shops.
http://www.bikerumor.com/2008/12/18/bikerumor-review-reel-light-commuter-bike-lights/
Posted : 23/07/2015 11:11 am
Surely a normal hub dynamo doesn't have any friction either (other than that of the axle bearings as per any other hub).
Yup and a whole hell of a lot less exposed too. But as a retrofit I can see the appeal of this system even if it is nothing new.
Always fancied some of those Reel Lights, look like a nice fit and forget option for secondary lights.
Posted : 23/07/2015 11:15 am
[quote=STATO ]Bin done.
Yep, and they suffer from the same issues this one will - that the spacing between stator and rotor has to be larger because there isn't the same control over tolerances you get if you build it all into a hub, and that increased spacing makes the efficiency a lot worse. As mentioned above it's only frictionless in the same sense that every other hub dynamo is frictionless - so long as you exclude the friction in the bearings which is just the same for this, and don't count the magnetic resistance (it's not back EMF, that's an electrical thing, but I CBA googling the correct term either).
The quoted efficiency in one of those links is surely BS.
Posted : 23/07/2015 11:26 am
well if you want truly frictionless, then these are what you want (i make no claim of the quality or ability to work or the stupidness of blocking half your light with a tyre).
https://www.reelight.com/en/products/city-supreme/city-supreme/city-supreme-steady-light-set/
Posted : 23/07/2015 11:31 am
I have an Exposure dynamo hub and a B&M front light/USB charger and rear brake and side light. Its very bright, fit and forget, and you can't tell you have a dynamo hub at all, this new idea doesn't seem like even half the quality/value. The light looks like Lego, and not good lego either....
Posted : 23/07/2015 11:35 am
At a fundamental level: You move a conductor through a magnetic field to induce an EMF. You can not make the EMF from nothing so there has to be some "work" done and there is your friction in the mechanism.
Make the magnetic field strong enough and cutting the lines of flux with a conductor becomes really, really hard. Try carrying an aluminum ladder through a 3 Tesla field and you know you are working.
Posted : 23/07/2015 11:36 am
Struggling to see any advantages over a set of lights with a couple of AAA batteries in.
As for USB charging never something I've felt I needed on a bike. Even iphone batteries aren't that cr*p.
Posted : 23/07/2015 11:41 am
Back EMF:
As the motor speed increases the eddy currents and the resulting back EMF also increase. When the motor reaches its maximum operating speed back emf will be generated at a constant rate. When a load is applied, the speed of the motor is reduced, which reduces the back emf and hence increases current in the motor. If the load stops the motor from moving then the current may be high enough to burn out the motor coil windings.
Generally, the load slows the armature down and so the current increases as the back emf is decreased. This produces an increase in current and torque to cope with the increased load.
Posted : 23/07/2015 11:44 am
If you run your phone as your GPS (Strava/Endomondo/CycleStreets/BikeHub etc) then it could be useful on longer rides - but personally I just carry a little battery pack for that.
Posted : 23/07/2015 11:47 am
dragon - Member
I know one nutter off this forum that decided to go out for a quick ride after dinner one December night last year. Got back to the house around 4am and 160miles later, no battery concerns required.
Posted : 23/07/2015 11:54 am
Wireless charging pad on the bars so hipsters can re-charge their iWatch whilst riding their fixie to the cafe for an artisan latte? Seems to be the target market 🙂
This looks like a much neater solution for providing USB power from a hub dynamo:
http://www.rosebikes.co.uk/article/supernova-the-plug-iii-usb-charger/aid:713880
(spendy though!)
Posted : 23/07/2015 12:05 pm
I'm glad we've established that:
-It looks shit.
-It costs more than retrofitting a decent set of hub dynamo lights.
-It will be less efficient due to the bigger air gap.
-If you want easier retrofit stuff, you can just use battery lights.
I have the B&M light with the USB charger, but I only got it for the remote on/off switch and marginally brighter light - you can't use the USB charger if it gets wet anyway unless you make an enclosure for it, but as others have said it might work for Iphone latte drinking hipsters in dry places.
Posted : 23/07/2015 12:08 pm
You can buy a Kemo USB charger for £30 at Maplins
Posted : 23/07/2015 12:09 pm
 Esme
Very useful if you're doing a long distance ride. I met a JOGLE rider last week, with something similar on his recumbent bike.
Posted : 23/07/2015 12:12 pm
That's where I'm going wrong I use a Garmin Etrex 10 for GPS and my phone well as a phone. Far lighter, cheaper and no resistance unlike a dynamo (plus non bike specific) and both will last days.
Posted : 23/07/2015 12:19 pm
Pfffffffffft
Posted : 23/07/2015 12:20 pm
I use a Garmin Etrex 10 for GPS and my phone well as a phone. Far lighter, cheaper..
Not sure how buying and carrying two different devices is lighter or cheaper than just one. 🙂
Posted : 23/07/2015 12:37 pm
My bike weights 60+lbs before I haul my lump onto it. The Nexus dynohub/B+M Werk combo charges stuff and powers a bright front LED. The only friction I notice are chafing comments from bike-tarts/pub-bores but even they soon leave me in their wake so I can cruise happily on in the knowledge that am still a smiling, juice-sipping tortoise 🙂
Posted : 23/07/2015 1:25 pm
Well I'm assuming you'll be carrying a phone anyway, so then it is a Garmin vs Dynamo in weight. As for cost basic Garmins are dirt cheap less than £100, no idea what price that dynamo will be but it'll cost more than that I'm sure.
Posted : 23/07/2015 1:48 pm
Which is why I said [i]"personally I just carry a little battery pack for that"[/i]. 😀
Posted : 23/07/2015 1:58 pm
Battery packs and having separate phone/gps dont help when you need a phone AND a gps in the scottish wilds when youve been camping for 3 days, but then this product is aimed at fixie-hipsters (who seemingly have 2 brakes and a freewheel so fixie-fakers) who will undoubtedly be riding to a coffee shop to browse a book of poetry for an hour or a barbers get their tash trimmed, so could easily charge their phone at said establishment.
Posted : 23/07/2015 2:13 pm
They do if you get a large enough capacity battery pack - or carry more than one. 😀
Posted : 23/07/2015 2:23 pm
[quote=STATO ]Battery packs and having separate phone/gps dont help when you need a phone AND a gps in the scottish wilds
I'm wondering how on earth I ever survived in the Scottish wilds without a phone or a GPS.
Posted : 23/07/2015 3:06 pm
Laptop?
Posted : 23/07/2015 3:11 pm
I've never used my phone or GPS unit in anger in the Scottish wilds. Now a compass and map, I would be lost without them (literally).
Posted : 23/07/2015 3:21 pm
FYI there’s a similar USB charging product already available at REI / Amazon / etc for less than half the price of the Cydekick at $130: http://sivacycle.com/products/atom.php .. plus it has a removable battery pack that you can charge in the wall before your ride just like any other portable extra battery back…
Posted : 27/07/2015 7:54 pm
