Karcher Pressure wa...
[Closed] Karcher Pressure washer problem
6 Users
I have a Karcher pressure washer that is over a year old now, and today as it was a bit warmer i washed the wife's and then my car, now the problem i have is when i got to my car the pressure started to fluctuate between normal and very weak!
If i stop using it for a few seconds then pull on the trigger i get full power for about 5 seconds. Then it returns to half power again.
Now all this i found quite odd as i had just used it on the wife's car with no problems.
So, has anyone else ever had a similar thing and what was the cause?
These things are supposed to be maintenance free too.
Posted : 11/01/2009 8:30 pm
your mains water pressure is borderline
ours does it sometimes
if you have variable output with a twist-handle, back it off a bit (though "power" will be down just a bit)
Posted : 11/01/2009 8:52 pm
Karchers only last for one year :-}
Posted : 11/01/2009 8:56 pm
There might be an inline filter on the water inlet side.
Make sure this is clean.
If it is, is more that likely water pressur that's causing it.
Posted : 11/01/2009 8:57 pm
I had a similar problem & it was the twist valve thing that switches between low & high sticking because of dirt
Try cleaning it & the jet at the end of the lance
Posted : 11/01/2009 8:59 pm
Thank guys, will give it a go soon.
Posted : 11/01/2009 9:09 pm
Usually caused by MrsSwadey putting on the washing machine just as I get the pressure washer started up - shouldn't make a difference, I think it does.....
Posted : 11/01/2009 9:18 pm
