IT help - Wifi boos...
[Closed] IT help - Wifi boosters, shared SSIDs and dropping out....
4 Users
Due to iffy wifi coverage at home, I've setup a homeplug booster and a wifi booster (off the homeplug booster) to spread the coverage. All seem to be working.
I've cunningly set all three APs to have the same SSID and password, thinking it would make life easier, but it appears to be causing conflicts. Checked the channels - main router on 1 and Homeplug booster on 6 (wifi booster also 6 because that's the setup its boosting)
Tablet and laptops seem ok, but I'm having issues with phones dropping signal then reconnecting. Also, my wifi printer is refusing to connect to anything. Any suggestions? Should I set them all to the same channel? Or use individual SSIDs?
Posted : 27/07/2015 8:53 am
IME, you don't get seamless transition when moving around even if they're on the same channel and SSID/pw
That said, I have different SSIDs for all three of my routers/APs so I can at least tell which one I'm connected to if I want to. They are all on the same channel though.
Posted : 27/07/2015 8:55 am
You can get a seamless setup but it's normally on the high end business kit.
Most of the home gear is separate wireless networks - even if you use same SSID and password. I'd just go for separate SSIDs and use a WiFi scanner app on an Android phone to see what shows up in each area and set the channel to the least congested for that area.
Posted : 27/07/2015 10:29 am
Thanks
Mind if I ask why?
Posted : 27/07/2015 12:17 pm
TBH because when I set the repeaters up, I assumed they needed to be. They seem to work fine so I've never changed it.
Posted : 27/07/2015 12:54 pm
Cheers. I might try that then...
Posted : 27/07/2015 2:13 pm
You'll need different SSIDs, they won't hand off properly without a central WLAN controller (i.e. not home kit).
I have the same issue with phones, all iPhones, they will doggedly stick to the first SSID they acquire until you flip wireless off and on. Not sure there is a fix for that when you look at how they auto select the hot spot to use.
Posted : 27/07/2015 2:40 pm
Problem solved.
Took the Wifi booster out of the loop. With just the main router and the homeplug, everything seems hunk-dorey - they're far enough apart that there's no quandry over strongest signal. As an added bonus, the wifi booster is now residing in the garage where it picks up enough signal to bounce it on, so I have streaming music while I fettle. And its all still on the same SSID and password. Result.
Posted : 30/07/2015 10:46 am
